When I was installing java jdk using sudo apt-get install build-essential
I was getting the error 404 the file was not found after I followed the solution given in
Can't install Oracle JDK 9 which is to change all files oracle-java9-installer.* change version numbers and SHA256SUM_TGZ as below
177-> 178
arm32: c24e8a5ce4dcf77d6e01362ae2d0a57997bb5018da1d74b6934e050d9d3515c7
arm64: 9839c453b7321e491ee752f2e612ca570caaffcf84cf07bf3776f388bb1ecdba
the installation fails in post installation :
Download done.
Removing outdated cached downloads...
sha256sum mismatch jdk-9+178_linux-x64_bin.tar.gz
Oracle JDK 9 is NOT installed.
dpkg: error processing package oracle-java9-installer (--configure):
 subprocess installed post-installation script returned error exit status 1
Is there any way to fix this?
I am running Ubuntu 16.04
Zanna
  • 72,312
I stuck in this problem almost 1 week.
 sudo apt-get purge oracle-java9-installer
solved my issue. Later I also changed Ubuntu Software center server to "Main Server".
