I've created a dynamic virtual host using this configuration file:
UseCanonicalName Off
<VirtualHost *:80>
    ServerName %1.dev
    ServerAlias *.%1.dev
ServerAdmin daniel@localhost
VirtualDocumentRoot /home/daniel/public_html/%1
LogLevel error rewrite:trace8 proxy:trace2
ErrorLog /home/daniel/public_html/error.log
CustomLog /home/daniel/public_html/access.log combined
&lt;Directory ~ &quot;/home/daniel/public_html/.*&quot;&gt;
    Options Indexes FollowSymlinks Multiviews
    AllowOverride All
    Require all granted
    DirectoryIndex index.php index.html
    RewriteEngine On
    &lt;FilesMatch &quot;\.php$&quot;&gt;
        SetHandler &quot;proxy:unix:/run/php/php7.0-fpm.sock|fcgi://localhost:9000&quot;
    &lt;/FilesMatch&gt;
&lt;/Directory&gt;
</VirtualHost>
This works fine with php scripts, but I can't make it work with SEF URLs such as those used by WordPress (e.g. http//mysite.dev/blog return 404).
Any ideas on this?
sotirov
  • 4,379
To make that work you need to enable rewrite module in Apache.
See this: https://www.digitalocean.com/community/tutorials/how-to-set-up-mod_rewrite-for-apache-on-ubuntu-14-04
After you have the module you will need something like this (wordpress example):
# BEGIN WordPress
<IfModule mod_rewrite.c>
RewriteEngine On
RewriteBase /
RewriteRule ^index\.php$ - [L]
RewriteCond %{REQUEST_FILENAME} !-f
RewriteCond %{REQUEST_FILENAME} !-d
RewriteRule . /index.php [L]
</IfModule>
# END WordPress
This should be placed in either .htacccess file or vhost file.
Check your Apache config file and enable rewrite for all.
Open terminal and write: nano /etc/apache2/apache2.conf
Find these lines and write exactly this code :
<Directory /var/www/>
    Options Indexes FollowSymLinks
    AllowOverride All
    Require all granted
</Directory>
Change AllowOverride none to AllowOverride All.
sotirov
  • 4,379
