I am using latest ubuntu. My language changed to chinese somehow. Everything comes in chinese and I couldn't get it back to english. Tried changing in language support, but english is written in chinese which I don't understand :(
Is there a way to change back to english using terminal and not gui way?
Jorge Castro
  • 73,717
nizam.sp
  • 131
The ~/.pam_environment file was the source of my problem. In /etc/default/locale and ~/.pam_environment
I edited the second file here to have:
LANGUAGE=en_US.UTF-8:en
LANG=en_US.UTF-8
(for US users). You will probably see other entries in .pam_environment that are correct, so you can cut and paste these into the above two variables. Note the ending ":en" for the LANGUAGE variable which appears to be unique for that variable.
From sacadough on the thread:
Jorge Castro
  • 73,717
gh423
  • 51
Exactly the same thing happened to me just now.
English in Chinese is 英語 (Traditional) and 英语 (Simplefied) (thanks - and copied from comment from @titaniumtux)
I was able to change it back using the keyboard layout options in Settings.
fossfreedom
  • 174,526
Here is what you have to do:
Just fix the locales with this process:
First run locale to list what locales currently defined for the current user account:
$ locale
LANG=C
LANGUAGE=
LC_CTYPE=fi_FI.UTF-8
LC_NUMERIC="C"
LC_TIME="C"
LC_COLLATE=fi_FI.UTF-8
LC_MONETARY="C"
LC_MESSAGES=fi_FI.UTF-8
LC_PAPER="C"
LC_NAME="C"
LC_ADDRESS="C"
LC_TELEPHONE="C"
LC_MEASUREMENT="C"
LC_IDENTIFICATION="C"
LC_ALL=
Then generate the missing locale and reconfigure locales to take notice:
$ sudo locale-gen "en_US.UTF-8"
Generating locales...
  en_US.UTF-8... done
Generation complete.
$ sudo dpkg-reconfigure locales Generating locales... en_US.UTF-8... up-to-date Generation complete.
Now, that will fix both your locales, but also it will default your language to english to fix the problem.
For more view this: How do I fix my locale issue?
Solved the Language issue by a logical way.
Today my Ubuntu 10.04 shows menus and sub-menus in Chinese (中文) Language. Even Terminal too.
  1. I used trial and error method. Finally Solved my issue.
  2. I took Keyboard Layout settings from Panel.
  3. A pop-up window appeared. But I couldn’t read there anything in Languages menu. Because Chinese Language was there.
  4. I took English to Chinese in Google search. Typed English (United States) In the box for Enlish and google converted it to 英语(美国)
  5. Searched the letters in my Languages menu and i found it. (There was a heading, 'Change will be applied next time you login'- "Yes, remember it")
  6. Again I took the next menu in Keyboard layout named Formats, changed the format to 英语(美国); this means English (United states) - "Thanks, google". (If we cannot see the 英语(美国) English (United states), You click on the "+" button in the bottom and select which you want from there
  7. Just closed the pop-up window and System Rebooted. All menus and Sub-menus Smiled with English(US) language. Solved my issue!!!
