Pilot6 is correct, there's no packages for Ubuntu 17.04 (Zesty Zapus) in that PPA. You can, however, point your PPA to the packages for the Ubuntu 16.04 or 16.10 releases and get the packages that way. To do that, hit Super, type 'Software & Updates', press Enter. Click on the 'Other Software' tab, then click on the PPA, then 'Edit...'. Change 'Distribution:' to 'yakkety' or 'xenial' (both without quotes).
However, this is not really the way you want to be getting Android Studio, that PPA looks out-of-date. You have two options for installing Android Studio (sadly I'm not aware of a snap of Android Studio yet).
Use Ubuntu's tool - Ubuntu Make
sudo apt install ubuntu-make
umake android
This seems the easier way to install Android Studio.
Install manually
- Download Android Studio
- If running a 64-bit version of Ubuntu, run
sudo add-apt-architecture i386 ; sudo apt-get install libc6:i386 libncurses5:i386 libstdc++6:i386 lib32z1 libbz2-1.0:i386
- Unpack the .zip file you downloaded to an appropriate location for your applications, such as within /usr/local/ for your user profile, or /opt/ for shared users.
- To launch Android Studio, open a terminal, navigate to the android-studio/bin/ directory, and execute studio.sh.
- Select whether you want to import previous Android Studio settings or not, then click OK.
- The Android Studio Setup Wizard guides you though the rest of the setup, which includes downloading Android SDK components that are required for development.
- To make Android Studio available in your list of applications, select Tools > Create Desktop Entry from the Android Studio menu bar.
Source for Ubuntu Make install instructions
Source for the manual install (click 'Linux' under 'Instructions for')
