Here is how it appears:
It disappeared after I responded to "yes" to a message that told me something about removing a non working file, but to be honest I didn't read that well and just said yes :c
I hope I'll get some help
zx485
  • 2,865
Try to completely reinstall GNOME, just open open the Terminal and run:
sudo apt-get remove ubuntu-gnome-desktop
sudo apt-get remove gnome-shell
sudo apt-get remove --auto-remove ubuntu-gnome-desktop
sudo apt-get purge --auto-remove ubuntu-gnome-desktop
sudo apt-get autoremove
sudo apt-get update
sudo apt-get install ubuntu-gnome-desktop
then reboot.
Exil
  • 545
Try to reinstall the GNOME desktop packages. Login to Unity (or to another desktop environment of your choice like KDE or press Ctrl-Alt-F1 to go to the tty1 session which is a CLI/Command Line Interface) , open a Terminal window (or go to tty1 as I said above) and run this command:
sudo apt-get install --reinstall gnome
Since the GNOME Panel files are corrupted, you need to reinstall the GNOME packages because you don't know what files are corrupted. So, a reinstallation is recommended.
Hope this helps. If you need more, feel free to contact me.
na-no.
  • 856
  • 24
