The mouse speed on my computer is too fast. I am running Ubuntu 16.04.
I followed the instructions here: Mouse speed too fast
And it worked, except every time I restart my computer I now need to re run that command. If it helps I am dual booting with windows 10 which means I restart my computer quite frequently. Where can I set the default value for the xinput prop so I get the settings I want on startup?
Zanna
  • 72,312
You can put that command mentioned here Mouse speed too fast at the end of ~/.profile will run the command automatically when you login into your system.
Run sudo nano ~/.profile to be able to edit it. Add the command at the end, save the file and exit. It should work correctly.
For further information about running a command on startup:
How to run a command at login?
Peshmerge
  • 698
