this is especially noticeable in code editors, where there is more than usual re-drawing going on. But lag also happens in web browsers when navigating and scrolling. Scrolling seems to lag, too. so.. not sure what's going on there.
I don't even know where to start.
Here is some system info:
Graphics Card(s):
01:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Venus XT [Radeon HD 8870M / R9 M270X/M370X] (rev 83)
Connected Monitors:
[    20.895] (II) RADEON(0): Output eDP connected
[    20.895] (II) RADEON(0): Output DisplayPort-1 connected
Current Video Driver:
drm_kms_helper        151552  2 amdgpu,radeon
syscopyarea            16384  1 drm_kms_helper
sysfillrect            16384  1 drm_kms_helper
sysimgblt              16384  1 drm_kms_helper
fb_sys_fops            16384  1 drm_kms_helper
drm                   352256  7 amdgpu,radeon,ttm,drm_kms_helper
Video Output Locations:
find: ‘/dev/vboxusb’: Permission denied
/dev/fb0
/dev/dri/card0
/dev/dri/renderD128
Grub boot command:
BOOT_IMAGE=/boot/vmlinuz-4.10.0-27-generic.efi.signed root=UUID=318b46d7-0efc-4fed-a30f-0c7406e13352 ro quiet splash acpi_backlight=vendor vt.handoff=7
modprobe.d drivers:
/etc/modprobe.d/
/etc/modprobe.d/iwlwifi.conf
/etc/modprobe.d/mlx4.conf
/etc/modprobe.d/blacklist-firewire.conf
/etc/modprobe.d/blacklist-framebuffer.conf
/etc/modprobe.d/blacklist-oss.conf
/etc/modprobe.d/blacklist-rare-network.conf
/etc/modprobe.d/qemu-system-x86.conf
/etc/modprobe.d/blacklist.conf
/etc/modprobe.d/blacklist-modem.conf
/etc/modprobe.d/alsa-base.conf
/etc/modprobe.d/intel-microcode-blacklist.conf
/etc/modprobe.d/blacklist-ath_pci.conf
/etc/modprobe.d/blacklist-watchdog.conf
/etc/modprobe.d/vmwgfx-fbdev.conf
/etc/modprobe.d/fbdev-blacklist.conf
Do we have a xorg.conf file?
ls: cannot access '/etc/X11/xorg.conf': No such file or directory
glxinfo:
/home/me/scripts/system-utils/graphics-info: line 25: glxinfo: command not found
Drivers loaded by Xorg:
[    20.463] (II) LoadModule: "glx"
[    20.477] (II) LoadModule: "ati"
[    20.479] (II) LoadModule: "radeon"
[    20.482] (II) LoadModule: "modesetting"
[    20.484] (II) LoadModule: "fbdev"
[    20.485] (II) LoadModule: "vesa"
[    20.501] (II) LoadModule: "fbdevhw"
[    20.504] (II) LoadModule: "fb"
[    20.507] (II) LoadModule: "dri2"
[    20.507] (II) LoadModule: "glamoregl"
[    20.895] (II) LoadModule: "ramdac"
[    21.628] (II) LoadModule: "evdev"
[    21.791] (II) LoadModule: "synaptics"
The above output is from:
#!/bin/bash
echo -e "\n\e[01;33mGraphics Card(s): \e[00m";
lspci | grep VGA;
echo -e "\n\e[01;33mConnected Monitors: \e[00m";
egrep -i " connected|card detect|primary dev" /var/log/Xorg.0.log;
echo -e "\n\e[01;33mCurrent Video Driver: \e[00m";
lsmod | grep "kms\|drm";
echo -e "\n\e[01;33mVideo Output Locations: \e[00m";
find /dev -group video;
echo -e "\n\e[01;33mGrub boot command: \e[00m";
cat /proc/cmdline;
echo -e "\n\e[01;33mmodprobe.d drivers: \e[00m";
find /etc/modprobe.d/;
echo -e "\n\e[01;33mDo we have a xorg.conf file?\e[00m";
ls /etc/X11/xorg.conf;
echo -e "\n\e[01;33mglxinfo: \e[00m";
glxinfo | grep -i "vendor\|rendering";
echo -e "\n\e[01;33mDrivers loaded by Xorg: \e[00m";
grep LoadModule /var/log/Xorg.0.log;
Also:
$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 16.04.2 LTS
Release:    16.04
Codename:   xenial
$ uname -a
Linux macbuntu 4.10.0-27-generic #30~16.04.2-Ubuntu SMP Thu Jun 29 16:07:46 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
Output from sudo dmidecode:
http://text-share.com/view/00d1973f
any help would be super appreciated :-)
Update
output from lspci -v (but just the snippet for VGA)
01:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Venus XT [Radeon HD 8870M / R9 M270X/M370X] (rev 83) (prog-if 00 [VGA controller])
    Subsystem: Apple Inc. Radeon R9 M370X Mac Edition
    Flags: bus master, fast devsel, latency 0, IRQ 37
    Memory at 80000000 (64-bit, prefetchable) [size=256M]
    Memory at b0c00000 (64-bit, non-prefetchable) [size=256K]
    I/O ports at 3000 [size=256]
    Expansion ROM at b0c40000 [disabled] [size=128K]
    Capabilities: <access denied>
    Kernel driver in use: radeon
    Kernel modules: radeon, amdgpu
