My Ubuntu Login is stuck in a loop.When ever I try to login it comes back to the login screen. I have tried various already options Mainly to open console using CTR+ALT+F1 but I wasn't able to login it from there as well. Bash opens up when ever I try to login in the console. Also have tried various solutions related to .Xauthority but whenever I try to use a command containing it says . Xauthority not exits.
Asked
Active
Viewed 194 times
In case it helps someone, something similar happened to me, I had the automatic login enabled and after updating the system the ubuntu login it would not let me log in
The solution was to comment on the lines of the automatic login accessing from the console in file /etc/gdm3/custom.conf
#AutomticLoginEnable=true
#AutomaticcLogin=name
franciscorode
- 101
