-1
root@campaigns:/var/lib/dpkg/info# apt-get -f install
Reading package lists... Done
Building dependency tree
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
    LANGUAGE = (unset),
    LC_ALL = (unset),
    LANG = "en_IN"
    are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
locale: Cannot set LC_CTYPE to default locale: No such file or directory
locale: Cannot set LC_MESSAGES to default locale: No such file or directory
locale: Cannot set LC_ALL to default locale: No such file or directory
Setting up etcd (2.2.5+dfsg-1ubuntu1) ...
Job for etcd.service failed because the control process exited with error code. See "systemctl status etcd.service" and "journalctl -xe" for details.
invoke-rc.d: initscript etcd, action "start" failed.
● etcd.service - etcd - highly-available key value store
   Loaded: loaded (/lib/systemd/system/etcd.service; enabled; vendor preset: enabled)
   Active: failed (Result: exit-code) since Wed 2017-07-19 16:18:52 UTC; 9ms ago
     Docs: https://github.com/coreos/etcd
       man:etcd
  Process: 13475 ExecStart=/usr/bin/etcd $DAEMON_ARGS (code=exited, status=1/FAILURE)
 Main PID: 13475 (code=exited, status=1/FAILURE)
Jul 19 16:18:52 campaigns etcd[13475]: etcd Version: 2.2.5
Jul 19 16:18:52 campaigns etcd[13475]: Git SHA: Not provided (use ./build instead of go build)
Jul 19 16:18:52 campaigns etcd[13475]: Go Version: go1.6.2
Jul 19 16:18:52 campaigns etcd[13475]: Go OS/Arch: linux/amd64
Jul 19 16:18:52 campaigns etcd[13475]: setting maximum number of CPUs to 2, total number of available CPUs is 2
Jul 19 16:18:52 campaigns etcd[13475]: error listing data dir: /var/lib/etcd/default
Jul 19 16:18:52 campaigns systemd[1]: etcd.service: Main process exited, code=exited, status=1/FAILURE
Jul 19 16:18:52 campaigns systemd[1]: Failed to start etcd - highly-available key value store.
Jul 19 16:18:52 campaigns systemd[1]: etcd.service: Unit entered failed state.
Jul 19 16:18:52 campaigns systemd[1]: etcd.service: Failed with result 'exit-code'.
dpkg: error processing package etcd (--configure):
 subprocess installed post-installation script returned error exit status 1
 etcd
I get the above error when I try installing anything. My Ubuntu version is 16.04.
You're having a problems with your locales setting. You can resolve it with this command:
$ sudo dpkg-reconfigure locales
Pick your language from the dropdown. With my language being American English I pick en_US.UTF-8 UTF-8.
This will generate the selected locales and character set.
Note:
You could probably avoid many problems by using a normal user's login rather than root when using the computer. When you need something systemwide to happen, elevate that particular command with by prefixing it with sudo. Something unintended has corrupted your locale settings.
L. D. James
  • 25,444
Unfortunately configuring locales did not work for me. What finally worked for me was:
sudo apt-get remove --purge etcd
sudo reboot now
Then after the reboot completes:
sudo apt-get install etcd
Eliah Kagan
  • 119,640
