I download an application from a website in its .tar.bz2 form as opposed to through apt-get or through the software center as I usually do (I don't think it matters but just in case, the application in question is Sublime Text 2).
To install it I just extracted the folder to /usr/share with sudo privileges however I can't seem to be able to add it to the dash, I know I can pin it to the launcher but I would like to know how to properly install files myself as this is clearly the incorrect way of doing it.
Thanks in advance.
Anwar
  • 77,855
Richie
  • 153
for adding manually installed program to the dash and launcher you have to write a desktop files for it (which end with .desktop ) .
the desktop file have this form in usual :
[Desktop Entry]
Name=application name
Exec=the command which you have to launch your application
Comment= a small description for this application
Icon= the directory for the icon which you want
this file is a very simple one , there is a lot of options that you can add to it .
then you have to put it into this directory :
/usr/share/applications/
if you want to add an icon for this program add your icon to this directory :
/usr/share/pixmaps
and then configure the .desktop file to user this icon .(in the Icon field )
it will appear in the dash now , or you may have to logout and login again.
eyadof
  • 1,494
