Important stuff:
Hello users of Ubuntu. Recently I have decided to step into the Ethereum mining world and compile ethminer myself. After installing cuda however, I ran into a small problem. While doing sudo cmake --build . after cmake .. -DETHASHCUDA=ON -DETHASHCL=OFF, the console outputted this:
[ 0%] Built target BuildInfo.h
[ 29%] Built target devcore
[ 41%] Built target ethash
[ 45%] Building NVCC (Device) object libethash-cuda/CMakeFiles/ethash-cuda.dir/ethash-cuda_generated_ethash_cuda_miner_kernel.cu.o
In file included from /usr/local/cuda/include/cuda_runtime.h:78:0,
from <command-line>:0:
/usr/local/cuda/include/host_config.h:119:2: error: #error -- unsupported GNU version! gcc versions later than 5 are not supported!
CMake Error at ethash-cuda_generated_ethash_cuda_miner_kernel.cu.o.Release.cmake:222 (message):
Error generating
/home/diamond/ethminer/build/libethash-cuda/CMakeFiles/ethash-cuda.dir//./ethash-cuda_generated_ethash_cuda_miner_kernel.cu.o
libethash-cuda/CMakeFiles/ethash-cuda.dir/build.make:63: recipe for target 'libethash-cuda/CMakeFiles/ethash-cuda.dir/ethash-cuda_generated_ethash_cuda_miner_kernel.cu.o' failed
make[2]: *** [libethash-cuda/CMakeFiles/ethash-cuda.dir/ethash-cuda_generated_ethash_cuda_miner_kernel.cu.o] Error 1
CMakeFiles/Makefile2:232: recipe for target 'libethash-cuda/CMakeFiles/ethash-cuda.dir/all' failed
make[1]: *** [libethash-cuda/CMakeFiles/ethash-cuda.dir/all] Error 2
Makefile:149: recipe for target 'all' failed
make: *** [all] Error 2
Additional info:
I installed CUDA using sudo apt install cuda. It installed nvidia-275 and cuda itself (along with a lot other stuff)
