I have a flashdisk drive that can't mount or backup, but when I check with lsusb that flashdisk is detected:
➜ ~ lsusb
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 004: ID 0930:6544 Toshiba Corp. TransMemory-Mini / Kingston DataTraveler 2.0 Stick (2GB)
Bus 001 Device 003: ID 1bcf:2c18 Sunplus Innovation Technology Inc.
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
But, if it is detected then why doesn't my flashdisk exist in /dev/sdb? Does anyone know what happened to my flashdisk?
➜ ~ sudo fdisk -l
Disk /dev/sda: 465,8 GiB, 500107862016 bytes, 976773168 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: dos
Disk identifier: 0x00094cd3
Device Boot Start End Sectors Size Id Type
/dev/sda1 * 2048 195311615 195309568 93,1G 83 Linux
/dev/sda2 195313662 199311359 3997698 1,9G 5 Extended
/dev/sda3 199313408 942567423 743254016 354,4G 83 Linux
/dev/sda4 942569472 976773167 34203696 16,3G 83 Linux
/dev/sda5 195313664 199311359 3997696 1,9G 82 Linux swap / Solaris
Partition 2 does not start on physical sector boundary.
Partition table entries are not in disk order.
➜ ~ sudo parted -l
Model: ATA WDC WD5000LPVT-2 (scsi)
Disk /dev/sda: 500GB
Sector size (logical/physical): 512B/4096B
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
1 1049kB 100GB 100GB primary ext4 boot
2 100GB 102GB 2047MB extended
5 100GB 102GB 2047MB logical linux-swap(v1)
3 102GB 483GB 381GB primary ext4
4 483GB 500GB 17,5GB primary ext4
➜ ~ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sda 8:0 0 465,8G 0 disk
├─sda1 8:1 0 93,1G 0 part /
├─sda2 8:2 0 1K 0 part
├─sda3 8:3 0 354,4G 0 part /media/agaust/Data
├─sda4 8:4 0 16,3G 0 part
└─sda5 8:5 0 1,9G 0 part [SWAP]
sr0 11:0 1 1024M 0 rom
I also tried to check it via Disks:
