I have one domain like http://example.com. This results in a page loaded from /var/www/example. Now I want all requests to http://example.com/site2 to be resolved to the folder /var/www/site2.
This is the basic idea and I tried to accomplish it like this (which did not work):
<VirtualHost *:80>
    ServerAdmin webmaster@example.com
DocumentRoot /var/www/example
DirectoryIndex /index.html index.html
#&lt;LocationMatch &quot;^/site2.*&quot;&gt;
#    RewriteEngine on
#    RewriteRule . /example2/index.html [L]
#&lt;/LocationMatch&gt;
AliasMatch &quot;/site2(.*)&quot; &quot;/var/www/site2$1&quot;
&lt;Directory /var/www/site2&gt;
    Require all granted
    AllowOverride all
&lt;/Directory&gt;
# Available loglevels: trace8, ..., trace1, debug, info, notice, warn,
# error, crit, alert, emerg.
# It is also possible to configure the loglevel for particular
# modules, e.g.
#LogLevel info ssl:warn
ErrorLog ${APACHE_LOG_DIR}/error.log
CustomLog ${APACHE_LOG_DIR}/access.log combined
# For most configuration files from conf-available/, which are
# enabled or disabled at a global level, it is possible to
# include a line for only one particular virtual host. For example the
# following line enables the CGI configuration for this host only
# after it has been globally disabled with &quot;a2disconf&quot;.
#Include conf-available/serve-cgi-bin.conf
</VirtualHost>
I tried using the Alias directive and LocationMatch to rewrite stuff to the correct URL when arriving at the /site2 URL. This was my conf. At http://example.com/site2/ it would result in the index.html from http://example.com/. Only when requesting http://example.com/site2/index.html.
<VirtualHost *:80>
Alias &quot;/site2&quot; &quot;/var/www/site2&quot;
    Require all granted
    AllowOverride all
&lt;/Directory&gt;
</VirtualHost>
I would also like to have all PHP requests passed to their own FPM pool. The requests for http://example.com should be passed to fcgi://127.0.0.1:9000 and the request for http://example.com/site2 should go to fcgi://127.0.0.1:9001.
How can I achieve this?
According to "Question 1)":
  • you should add an alias:
    Alias /site2 /var/www/site2
    <Directory /var/www/site2>
        Require all granted
        AllowOverride all
    </Directory>
  • The DirectoryIndex directive reads the statements as 'absolute' filenames. I mean with this syntax:
    DirectoryIndex will check if index.html, located in DocumentRoot=/, exists and will display it if yes, and will ignore next statements. So if this record (/index.html) is not intended it is wrong. Some examples here.
pa4080
  • 30,621
