24
I have thought that /usr/bin/startx script is used to start the X server but it looks like it is not true. Which process or script starts the X server? The X server has to be started before lightdm greeter is visible but when exactly?
kasperd
  • 1,779
Irbis
  • 507
Boot into a text screen and use startx
If your Ubuntu system boots into a text screen, for example a minimal system or a server system, you can use startx to start xserver (and a simple window manager like openbox or fluxbox or a desktop environment like gnome, kde, lxde, ... xfce).
For example, it is enough to start and use a simple graphical desktop (in a minimal or server system) after three program packages are installed,
sudo apt update
sudo apt install fluxbox xinit xterm
with the command
startx
Boot directly into a graphical desktop
If you have an Ubuntu desktop system (standard Ubuntu or one of the community flavours Kubuntu, Lubuntu, ... Xubuntu), you need not use startx, the graphical desktop environment is started automatically (and you need not run startx). If I understand correctly, it is started via systemd. See for example the following links,
wiki.archlinux.org/index.php/Systemd/User#Xorg_and_systemd
wiki.archlinux.org/index.php/xorg
Switch between text mode and graphic mode
Switching between text mode and graphics mode is described in the accepted answer of the following link
Booting into text mode in 16.04
To boot Ubuntu 16.04 Desktop without X one time, add systemd.unit=multi-user.target to the linux command line in GRUB.
To make this the default, use
sudo systemctl set-default multi-user.target
To return to default booting into X, use
sudo systemctl set-default graphical.target
To see the current default target,
sudo systemctl get-default
sudodus
  • 47,684
14
/etc/init.d/lightdm starts the Xserver. Lightdm gets started first then it starts the Xserver. The parent process of the Xserver (Xorg) is lightdm (PID 25600 as shown in example below). You can see this by executing:
ps -ef | grep lightdm
root 25600 1 0 00:50 ? 00:00:00 /usr/sbin/lightdm
root 25608 25600 2 00:50 tty7 00:00:35 /usr/lib/xorg/Xorg -core :0 -seat seat0 -auth /var/run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch
root 25686 25600 0 00:50 ? 00:00:00 lightdm --session-child 12 19
Running the following commands will stop and start lightdm and Xserver accordingly:
sudo /etc/init.d/lightdm stop
sudo /etc/init.d/lightdm start
stumblebee
  • 4,379
You can read about the boot up process here: http://manpages.ubuntu.com/manpages/xenial/man7/boot.7.html
Although the manual does not mention Xserver (or X11), the init process is responsible for starting the Xserver.
urben
  • 421
Init proccess (PID=1) spawning everything, usually including x11
In 16.04 it is /sbin/init of systemd-sysv
Joe Ford
  • 169
