I am building a router using 16.04.2. After installing SSH, renaming/setting up the interfaces then installing Bind, I noticed it is taking about 5 minutes for ssh and bind to start responding (ICMP starts responding within 30 seconds). Once the services come up things seem to be working okay.
Also, I found I am getting this error when restarting network:
sudo /etc/init.d/networking restart
[....] Restarting networking (via systemctl): networking.serviceJob for networking.service failed because the control process exited with error code. See "systemctl status networking.service" and "journalctl -xe" for details.
failed!
So I'm thinking it has something to do with renaming/setup the interfaces. I followed the intructions here to modify grub: Changing Network Interfaces name Ubuntu 16.04 then I created /etc/udev/rules.d/70-persistent-net.rules:
# spectrum
SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="f0:4d:a2:24:99:af", ATTR{dev_id}=="0x0", ATTR{type}=="1", NAME="eth0spectrum"
# name1.lan
SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="00:1b:21:86:52:31", ATTR{dev_id}=="0x0", ATTR{type}=="1", NAME="eth1name1"
# name2.lan
SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="00:1b:21:86:52:30", ATTR{dev_id}=="0x0", ATTR{type}=="1", NAME="eth2name2"
# available
SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="00:1b:21:86:52:33", ATTR{dev_id}=="0x0", ATTR{type}=="1", NAME="eth3"
# available
SUBSYSTEM=="net", ACTION=="add", DRIVERS=="?*", ATTR{address}=="00:1b:21:86:52:32", ATTR{dev_id}=="0x0", ATTR{type}=="1", NAME="eth4"
Then set up /etc/network/interfaces:
# interfaces(5) file used by ifup(8) and ifdown(8)
auto lo
iface lo inet loopback
auto eth0spectrum
iface eth0spectrum inet dhcp
auto eth1name1
iface eth1name1 inet static
address 10.27.66.3
netmask 255.255.255.0
network 10.27.66.0
broadcast 10.27.66.255
gateway 10.27.66.1
dns-nameservers 127.0.0.1
auto eth2name2
iface eth2name2 inet static
address 10.28.66.1
network 10.28.66.0
broadcast 10.28.66.255
gateway 10.28.66.1
auto eth3
iface eth3 inet dhcp
auto eth4
iface eth4 inet dhcp
output of systemctl status networking.service:
● networking.service - Raise network interfaces
Loaded: loaded (/lib/systemd/system/networking.service; enabled; vendor preset: enabled)
Drop-In: /run/systemd/generator/networking.service.d
└─50-insserv.conf-$network.conf
Active: failed (Result: exit-code) since Sun 2017-07-16 10:56:59 EDT; 15s ago
Docs: man:interfaces(5)
Process: 1976 ExecStart=/sbin/ifup -a --read-environment (code=exited, status=1/FAILURE)
Process: 1970 ExecStartPre=/bin/sh -c [ "$CONFIGURE_INTERFACES" != "no" ] && [ -n "$(ifquery --read-
Main PID: 1976 (code=exited, status=1/FAILURE)
Jul 16 10:56:59 cog systemd[1]: Starting Raise network interfaces...
Jul 16 10:56:59 cog ifup[1976]: RTNETLINK answers: File exists
Jul 16 10:56:59 cog ifup[1976]: Failed to bring up eth2name2.
Jul 16 10:56:59 cog systemd[1]: networking.service: Main process exited, code=exited, status=1/FAILURE
Jul 16 10:56:59 cog systemd[1]: Failed to start Raise network interfaces.
Jul 16 10:56:59 cog systemd[1]: networking.service: Unit entered failed state.
Jul 16 10:56:59 cog systemd[1]: networking.service: Failed with result 'exit-code'.
output of journalctl -xe
Jul 16 10:56:59 cog named[1127]: automatic empty zone: 100.51.198.IN-ADDR.ARPA
Jul 16 10:56:59 cog named[1127]: automatic empty zone: 113.0.203.IN-ADDR.ARPA
Jul 16 10:56:59 cog named[1127]: automatic empty zone: 255.255.255.255.IN-ADDR.ARPA
Jul 16 10:56:59 cog named[1127]: automatic empty zone: 0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0
Jul 16 10:56:59 cog named[1127]: automatic empty zone: 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0
Jul 16 10:56:59 cog named[1127]: automatic empty zone: D.F.IP6.ARPA
Jul 16 10:56:59 cog named[1127]: automatic empty zone: 8.E.F.IP6.ARPA
Jul 16 10:56:59 cog named[1127]: automatic empty zone: 9.E.F.IP6.ARPA
Jul 16 10:56:59 cog named[1127]: automatic empty zone: A.E.F.IP6.ARPA
Jul 16 10:56:59 cog named[1127]: automatic empty zone: B.E.F.IP6.ARPA
Jul 16 10:56:59 cog named[1127]: automatic empty zone: 8.B.D.0.1.0.0.2.IP6.ARPA
Jul 16 10:56:59 cog named[1127]: automatic empty zone: EMPTY.AS112.ARPA
Jul 16 10:56:59 cog named[1127]: reloading configuration succeeded
Jul 16 10:56:59 cog named[1127]: any newly configured zones are now loaded
-- Subject: Unit networking.service has failed
-- Defined-By: systemd
-- Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel
-- Unit networking.service has failed.
-- The result is failed.
Jul 16 10:56:59 cog sudo[1958]: pam_unix(sudo:session): session closed for user root
Jul 16 10:57:07 cog dhclient[1260]: DHCPDISCOVER on eth0spectrum to 255.255.255.255 port 67 interval 1
Jul 16 10:57:22 cog dhclient[1260]: DHCPDISCOVER on eth0spectrum to 255.255.255.255 port 67 interval 1
output of /var/log/syslog
Jul 16 10:54:34 cog dhclient[1260]: DHCPDISCOVER on eth0spectrum to 255.255.255.255 port 67 interval 10 (xid=0x2325a874)
Jul 16 10:54:44 cog dhclient[1260]: DHCPDISCOVER on eth0spectrum to 255.255.255.255 port 67 interval 9 (xid=0x2325a874)
Jul 16 10:54:53 cog dhclient[1260]: DHCPDISCOVER on eth0spectrum to 255.255.255.255 port 67 interval 13 (xid=0x2325a874)
Jul 16 10:55:06 cog dhclient[1260]: DHCPDISCOVER on eth0spectrum to 255.255.255.255 port 67 interval 16 (xid=0x2325a874)
Jul 16 10:55:22 cog dhclient[1260]: DHCPDISCOVER on eth0spectrum to 255.255.255.255 port 67 interval 19 (xid=0x2325a874)
Jul 16 10:55:41 cog dhclient[1260]: DHCPDISCOVER on eth0spectrum to 255.255.255.255 port 67 interval 14 (xid=0x2325a874)
Jul 16 10:55:55 cog dhclient[1260]: DHCPDISCOVER on eth0spectrum to 255.255.255.255 port 67 interval 10 (xid=0x2325a874)
Jul 16 10:56:05 cog dhclient[1260]: DHCPDISCOVER on eth0spectrum to 255.255.255.255 port 67 interval 10 (xid=0x2325a874)
Jul 16 10:56:15 cog dhclient[1260]: DHCPDISCOVER on eth0spectrum to 255.255.255.255 port 67 interval 20 (xid=0x2325a874)
Jul 16 10:56:35 cog dhclient[1260]: DHCPDISCOVER on eth0spectrum to 255.255.255.255 port 67 interval 11 (xid=0x2325a874)
Jul 16 10:56:46 cog dhclient[1260]: DHCPDISCOVER on eth0spectrum to 255.255.255.255 port 67 interval 10 (xid=0x2325a874)
Jul 16 10:56:56 cog dhclient[1260]: DHCPDISCOVER on eth0spectrum to 255.255.255.255 port 67 interval 11 (xid=0x2325a874)
Jul 16 10:56:59 cog systemd[1]: Stopped Raise network interfaces.
Any ideas how to fix this? Any assistance would be greatly appreciated.
