Sometimes I get interrupted while programming and would like to have some sort of alarm function that can remind me to do sometihing important.
I do not want to build a clock, nor do I want the kind of thing my smartphone does.
Just an on-screen reminder would be best. Non-recurring. I know there used to be a program called reminder that would do this. I also know about sticky-notes but have a policy of never changing my repositories for any reason. Also there is one called something like remindor but it won't work with 16.04 LTS.
So now I can't locate anything similar.
Maybe someone in the community knows this.
How can I make my Ubuntu do this easily? Hopefully with just a single command (because this is usually in response to a phone call for help elsewhere).
---EDIT: I had to actually install the at command on Ubuntu 16.04 LTS:
sudo aptitude install at
SDsolar
  • 3,219
Here is one that does the pop-up notifications. It will work from the command line, and even works in cron jobs.
The simplest way to use it is like so:
echo 'notify-send "FINISH THAT MIDNIGHT PROGRAM"' | at 20:00
(Thank you, @M. Becerra)
It presents a pop-up in the upper right of all the desktops but without command-line parameters it is silent and goes away in just a few seconds, so here is a good article that explains the high points:
Gnome Desktop Notifications Specification
It can make noises if necessary, for instance.
SDsolar
  • 3,219
There is a program called xpad that works from the command line and from the GUI. Install it like this:
sudo apt install xpad
Then to run it, type
xpad
It pops up a yellow sticky-note-like window so I can keep that on-screen to remind me to call the boss when I get back, or to finish something I was working on.
It can be locked to the taskbar in case it needs to be minimized. Also, when closed entirely, it comes back with the text intact. That's a plus.
Looks like it will be useful.
But I still need something that will pop up and interrupt me at a set time, whether as a one-off or as a daily cron.
SDsolar
  • 3,219
A utility program that will pop-up reminders is Day Planner (http://www.day-planner.org)
The developer's web site states: "Day Planner is a program designed to help you easily plan and manage your time. It can manage appointments, birthdays and more and makes sure you remember your appointments by displaying reminders."
CentaurusA
  • 2,692
Xterm can show a dingy little black reminder window... but it stays up until you close it, unlike notify-send.
This one-liner reads a line from the terminal, then displays the reminder in xterm after sleeping for ten minutes.
$ read -p 'reminder? ' e;e=`printf %q "$e"`; sleep $((60*10)) ; xterm -e bash -c "read -p $e"
Here's a bash one-liner using ebay-alarm
$ ebay-alarm 10 min -- xterm -e bash -c "read -p `printf "%q" "$(read -p 'reminder? ' e;echo $e)"`"
It's hard to read because the one-liner, uses this method: xterm -e bash -c "script" , but the reminder message has to be read, then escaped with printf.
marinara
  • 435
