I would like to know if there's a way - without installing a third party program - to view a graphical item, such as a photo, inside terminal.
I'm running Ubuntu 17.04
Thank you!
Without 3rd party applications, terminal cannot display graphics. It's only resolution is the text block.
richbl
  • 2,373
you can not view image inside the normal terminal.You can do that with some advance terminals.But I am going to tell you the another way for gnome terminal and other basic terminals in which you need to call the images with some other application.
suppose if you want to view xyz.png then type
xviewer xyz.png or
gwenview xyz.png or
depending upon your desktop environment.
Note: you can install xviewer by command
sudo apt install xviewer
and gpicview by
sudo apt install gpicview
and gwenview by
sudo apt install gwenview
