Configuring StartTLS for OpenLDAP.
  • Ubuntu server 16.04
  • Slapd 2.4.42+dfsg-2ubuntu3.2
I have my own internal Certificate authority that is providing certificates.
I have set up certificates and key: in /etc/ssl/certs:
-rw-r----- 1 root ssl-cert   3268 Jul 14 23:02 ldaptest.roenix.net.cert.pem
lrwxrwxrwx 1 root root         51 Jul  2 13:22 roenix.ca.cert.pem -> /usr/local/share/ca-certificates/roenix.ca.cert.crt
in /etc/ssl/private:
-rw-r----- 1 root ssl-cert 3243 Jul 14 23:01 ldaptest.roenix.net.key.pem
I have correctly set hostname:
@ldaptest:/etc/ssl/certs$ hostname -f
ldaptest.roenix.net
I try to add the configuration to slapd with this LDIF:
dn: cn=config
changetype: modify
add: olcTLSCACertificateFile
olcTLSCACertificateFile: /etc/ssl/certs/roenix.ca.cert.pem
add: olcTLSCertificateFile
olcTLSCertificateFile: /etc/ssl/certs/ldaptest.roenix.net.cert.pem
add: olcTLSCertificateKeyFile
olcTLSCertificateKeyFile: /etc/ssl/private/ldaptest.roenix.net.key.pem
With the command:
sudo ldapmodify -Y EXTERNAL -H ldapi:/// -f certinfo.ldif
I get this error:
SASL/EXTERNAL authentication started
SASL username: gidNumber=0+uidNumber=0,cn=peercred,cn=external,cn=auth
SASL SSF: 0
modifying entry "cn=config"
ldap_modify: Other (e.g., implementation specific) error (80)
Any help greatly appreciated!
Ph4edrus
  • 121
7 Answers7
I solved this problem by changing the order in the file.ldif like this:
dn: cn=config
changetype: modify
replace: olcTLSCertificateKeyFile
olcTLSCertificateKeyFile: /etc/openldap/certs/your_key
dn: cn=config
changetype: modify
replace: olcTLSCertificateFile
olcTLSCertificateFile: /etc/openldap/certs/your_certificate
and the I ran the command
ldapmodify -Y EXTERNAL -H ldapi:/// -f your_file.ldif
make sure that there an acl that makes the root eligible to make change with authenticating with SASL bind.
To make sure that changes have been done, run this command
ldapsearch -Y EXTERNAL -H ldapi:/// -b cn=config | grep olcTLS
Kulfy
  • 18,154
I had the same problem. Certificates were stored in the /opt/local/cert.
You must add this directory to the list of the resolved files in /etc/apparmor.d/local/usr.sbin.slapd:
/opt/local/cert/ r,
/opt/local/cert/* r,
dsh
  • 362
user798428
This error can be also a permission error. For example if did this command
vim newcerts.ldif
dn: cn=config
changetype: modify
replace: olcTLSCACertificateFile
olcTLSCACertificateFile: /etc/ssl/certs/myca.crt
olcTLSCertificateFile: /etc/ssl/certs/ldap1.mydom.crt
olcTLSCertificateKeyFile: /etc/ssl/private/ldap1.mydom.key
replace: olcTLSRandFile
olcTLSRandFile: /dev/urandom
then
ldapmodify -Y EXTERNAL -H ldapi:/// -f newcerts.ldif
SASL SSF: 0
but after give with setfacl the permission of read keyfile to openldap user(the certs are usually 644 readable by all)
setfacl -m u:openldap:r-x /etc/ssl/private
setfacl -m u:openldap:r-x /etc/ssl/private/ldap1.mydom.key
all works
SASL SSF: 0
elbarna
  • 224
I solved the problem just use in the correct order first key then cert. And it worked for me.
dn: cn=config
changetype: modify
olcTLSCertificateKeyFile: /etc/openldap/certs/myldap.kart.com.key
dn: cn=config
changetype: modify
olcTLSCertificateFile: /etc/openldap/certs/myldap.kart.com.cert
Thomas' comment put me on the right track.
Cause of the problem: I failed to realize that /etc/ssl/certs/roenix.ca.cert.crt is actually a symlink to /usr/local/share/ca-certificates/roenix.ca.cert.crt.
Solution: Set correct permissions on the actual cert file in /usr/local/share/ca-certificates.
Also read the other comments and learned a lot! Thanks all.
Ph4edrus
  • 121
Problem could also be that SELinux is preventing slapd from read access to the .key and .cert file. Please add policy for the files, dont turn SELinux off.
Having problem with SELinux. Use tool setroubleshoot.
Marlar
To help others like me, this error can also be triggered if you have a key with a passphrase. This seems trivial, but easily forgotten. And of course, the error message doesn't help.
To remove the passphrase, you can use:
openssl rsa -in my.key -out my_no_password.key
neuro
  • 101
