I have a kvm VM with Ubuntu 14.04 set as a firewall in a virtual network (with eth0 and eth1)
This is not a course but at work. I have to learn this.
Intermittently eth1 will fail to come up.
In /etc/network/interfaces both eth0 and eth1 are set manually.
When eth0 should be up there is a up command /etc/interim-fw.sh that allows nothing and no forwarding between the ports.
Then eth1. There is a pre-up where i send a comment to a log file that it has reached this point. Then link up also and then up command to /etc/firewall.sh that will load the iptables with all rules that are needed.
Randomly this will not load and only reach pre-up of eth1. But once the VM has loaded if I run bash /etc/firewall.sh it will load completely and all will be fine!
So my question is: How can I solve this? Why am I getting a race condition, if that is what I am getting?
/etc/network/interfaces:
auto lo
iface lo inet loopback
auto eth0
iface eth0 inet manual
  up ip a a 5.156.241.126/25 dev eth0
  up ip li set up dev eth0
  up /etc/interim-fw.sh
  down ifconfig eth0 0.0.0.0 down
 auto eth1
 iface eth1 inet manual
    up ip a a 5.156.241.129/27 dev eth1
    up ip li set up dev eth1
    up ip route add default via 5.156.241.158
    post-up /etc/firewall.sh
    down ifconfig $IFACE 0.0.0.0 down
/etc/firewall.sh
!/bin/bash -e
I_INT=eth0  # Intranet-LAN-Interface
I_DMZ=eth1  # DMZ-LAN-Interface
NAME=5.156.241.130
MASTER=5.156.241.1
UBUNTU=141.30.13.10,141.30.13.20,141.76.1.200,141.76.1.204,141.76.1.208
REACTOS=178.63.204.104,188.40.64.41
MOZILLA=52.222.170.144
PYTHON=151.101.0.223,151.101.64.223,151.101.128.223,151.101.192.223
MAIL=5.156.241.142
WWW=5.156.88.1
STATE_NEW="-m state --state NEW"
STATE_ESTABLISHED="-m state --state ESTABLISHED"
PING="-p icmp --icmp-type 8"                        #ICMP packet type 8 alias echo request (= ping request )
REM="-m comment --comment"
iptables-restore << @@@@@@@@
*filter
:INPUT DROP [0:0]
:FORWARD DROP [0:0]
:OUTPUT DROP [0:0]
-A INPUT -i lo -j ACCEPT
-A OUTPUT -o lo -j ACCEPT
-A INPUT   $STATE_ESTABLISHED -j ACCEPT
-A OUTPUT  $STATE_ESTABLISHED -j ACCEPT
-A FORWARD $STATE_ESTABLISHED -j ACCEPT
-A INPUT  -p icmp -m icmp --icmp-type any  $STATE_NEW  $REM "traceroute" -j ACCEPT
-A INPUT  -p udp      --dport 33434:33523  $STATE_NEW  $REM "traceroute" -j ACCEPT
-A INPUT   -i $I_INT -p tcp           --dport 22345 $STATE_NEW  $REM "ssh" -j ACCEPT
-A FORWARD -i $I_INT -o $I_DMZ -p tcp --dport 22345 $STATE_NEW  $REM "ssh" -j ACCEPT
-A OUTPUT -o $I_DMZ -d $SATURN -p tcp --dport 53  $STATE_NEW $REM "dns"  -j ACCEPT
-A OUTPUT -o $I_DMZ -d $SATURN -p udp --dport 53  $STATE_NEW $REM "dns"  -j ACCEPT
-A FORWARD -i $I_INT -o $I_DMZ -d $SATURN -p tcp --dport 53  $REM "dns" $STATE_NEW  -j ACCEPT
-A FORWARD -i $I_INT -o $I_DMZ -d $SATURN -p udp --dport 53  $REM "dns" $STATE_NEW  -j ACCEPT
-A FORWARD -i $I_INT -o $I_DMZ -d $MASTER -p tcp --dport 53  $REM "dns" $STATE_NEW  -j ACCEPT
-A FORWARD -i $I_INT -o $I_DMZ -d $MASTER -p udp --dport 53  $REM "dns" $STATE_NEW  -j ACCEPT
-A OUTPUT -o $I_DMZ $PING $STATE_NEW $REM "Ping"  -j ACCEPT
-A FORWARD -i $I_INT -o $I_DMZ $PING $STATE_NEW $REM "Ping" -j ACCEPT
-A FORWARD -i $I_INT -o $I_DMZ -d $UBUNTU -p tcp --dport 80 $STATE_NEW $REM "Ubuntu"  -j ACCEPT
-A FORWARD -i $I_INT -o $I_DMZ -d $REACTOS -p tcp -m multiport --dports 80,443 $STATE_NEW $REM "Reactos"  -j ACCEPT
-A FORWARD -i $I_INT -o $I_DMZ -d $MOZILLA -p tcp -m multiport --dports 80,443 $STATE_NEW $REM "Mozilla"  -j ACCEPT
-A FORWARD -i $I_INT -o $I_DMZ -d $PYTHON -p tcp -m multiport --dports 80,443 $STATE_NEW $REM "Python"  -j ACCEPT
-A OUTPUT            -o $I_DMZ -d $UBUNTU -p tcp --dport 80 $STATE_NEW $REM "Ubuntu"  -j ACCEPT
-A FORWARD -i $I_INT -o $I_DMZ -d $WWW -p tcp --dport 80 $STATE_NEW $REM "www"  -j ACCEPT
-A OUTPUT            -o $I_DMZ -d $WWW -p tcp --dport 80 $STATE_NEW $REM "www"  -j ACCEPT
COMMIT
  test $(sysctl -n net.ipv4.ip_forward) -eq 0 && sysctl net.ipv4.ip_forward=1  #Forwarding aktivieren
        echo "ok"
  echo "GOT HERE - ok!" >> /tmp/fw.log
  exit 0
  test $(sysctl -n net.ipv4.ip_forward) -ne 0 && sysctl net.ipv4.ip_forward=0  #Forwarding de-aktivieren
  /etc/firewall-vorlaeufig.sh
echo "GOT HERE - not ok " >> /tmp/fw.log
This does not duplicate How to save rules of the iptables? Reason is that my Senior Admin insists that I use this /etc/firewall.sh script. Also the script runs fine but randomly fails.
Thank you for your comments so far. I would really appreciate any help if trying to find out the cause of this. Thanks. Bob
Your situation is complicated as you are running a VM and you seem to be using some sort of script and you are trying to call the script in your network pre/post up/down rules.
IMO most of the "scripts" to generate rules for iptables are overly complex and completely unnecessary. Most scripts may seem "smart" but often the only purpose is obscurification of iptables.
Easiest way to save/restore your rules is with iptables-persistent
sudo apt-get install iptables-persistent
Once you install the package it will restore your rules no matter if you manually entered them or generated them from some sort of script.
If you really want help with your script you need to post it as well as your configuration files.
Panther
  • 104,528
