11
I have tried >> pkg install -forge statistics , but it showed
error: the following dependencies were unsatisfied: statistics needs io >= 1.0.18
What should I do now?
Rangerix
  • 471
I installed octave the following way:
sudo apt-get install octave
Then I ran
sudo apt-get install octave-statistics
If you then want to use a function from the statistics package, you will have to use (from the octave prompt):
pkg load statistics
That worked fine for me on Ubuntu 18.04
Cleb
  • 293
You should first install io: enter
pkg install -forge io
on the octave command line.
Then install the statistics package and when you want to use it enter
pkg load statistics
to load it.
ksyrium
  • 130
