I am following the instructions here to install a root certificate for Charles Proxy.
I followed every step exactly as it was outlined, and made sure to set the permissions correctly. However, when I run sudo update-ca-certificates, it outputs:
Updating certificates in /etc/ssl/certs...
0 added, 0 removed; done.
Running hooks in /etc/ca-certificates/update.d...
done.
done.
After this, the certificate remains untrusted. I also tried this, which is the same steps but tells me to install it in /usr/local/share/ca-certificates instead. When I do this, update-ca-certificates returns an error:
WARNING: Skipping duplicate certificate UbuntuOne-Go_Daddy_Class_2_CA.pem
WARNING: charles.pem does not contain a certificate or CRL: skipping
WARNING: dhparam.pem does not contain a certificate or CRL: skipping
1 added, 0 removed; done.
Adding debian:charles.pem
done.
done.
And it still does not work. Additionally, installing a SSL cert directly through Charles (Help -> SSL Proxying -> Install Charles Root Certificate) does not work, even though it says it installs successfully.
