UPDATE: I received an answer from Intel (finally):
As per our investigation, you will need an add-on device to use your
TV remote with Kodi.
The onboard HDMI CEC controller that is controlled from the BIOS,
supports bidirectional power on/off control for TV and NUC.
So you can NOT use the remote with the built in CEC.
PREVIOUS ANSWER (more in depth):
So from https://www.intel.com.au/content/www/au/en/support/boards-and-kits/intel-nuc-kits/000023500.html it states:
The following Intel NUC Kits have the above external CEC header as
well as an onboard HDMI CEC controller that is controlled by the BIOS,
which supports bidirectional power on/off control:
And then lists a bunch of NUC's including the Gen7 ones. From this (and other readings) it seems that the CEC controller in the NUC's are only for use in the BIOS (NOT the OS) and so can only be used to do power options (wake, power on/of etc) and so are really just a HDMI version of wake-on LAN.
So the fact that the place I got it from (and Intel) don't make this clear and just say there is a built in HDMI CEC controller is beside the point and hopefully people will find this post before purchasing.
YOU CAN NOT USE THE TV REMOTE TO CONTROL ANY NUC'S WITH THE BUILT IN HDMI CEC CONTROLLER. (At the current time up to the Gen7's)
In order to do this you will need something like https://www.pulse-eight.com/p/154/intel-nuc-hdmi-cec-adapter (internal, NUC specific) or https://www.pulse-eight.com/p/104/usb-hdmi-cec-adapter (External, multiple devices).
I will update this if I see any new firmware etc that changes this.
