I know touch & echo for creating an empty file. But how can I create an empty file in the home directory in one line? I have tried touch ~/boo.txt but it's creating the file. I'm new to shell, I need to know two approaches of creating an empty file in Home directory from another directory. TIA
Julfikar
  • 173
Here is an alternative to touch, just redirect nothing to a file:
> ~/newfile
Important: it will overwrite the file if it's already there, however you can use:
(set -C; > ~/newfile)
so it's not going to be overwritten if it's already exist.
here is another fun way to do this:
cat <<<"" >> ~/newfile
the cat is unnecessary so we can just use:
>> ~/newfile
Ravexina
  • 57,256
touch /home/username/newfile.txt
note:file and directory names are case sensitive
ravery
  • 6,924
You can use the truncate command, which will create the file if it doesn't exist. Be warned that this will also empty an existing file.
truncate -s 0 ~/newfile
Arronical
  • 20,241
