I have Ubuntu 16.04. I'm trying to make my WiFi work. First - the indicator on the functional button that supposed to switch wifi doesn't change color when I'm pushing it, but it switches bluetooth. I'm using driver that is recommended by Software and Updates. When I go to System Settings > Network > Wireless I can't turn on the trigger.
Laptop model: HP Pavilion 1062er. BIOS vendor: Insyde. BIOS version: F.27
08:00.0 Network controller [0280]: Broadcom Limited BCM4313 802.11bgn Wireless Network Adapter [14e4:4727] (rev 01)
DeviceName: Broadcom 802.11b/g/n WLAN
Subsystem: Hewlett-Packard Company BCM4313 802.11bgn Wireless Network Adapter [103c:1795]
Kernel driver in use: wl
Kernel modules: bcma, wl
$ rfkill list
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
1: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
2: brcmwl-0: Wireless LAN
Soft blocked: no
Hard blocked: yes
$ sudo lshw -c network
*-network
description: Ethernet interface
product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0.2
bus info: pci@0000:07:00.2
logical name: eno1
version: 0a
serial: 28:92:4a:18:87:b6
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full firmware=rtl8411-1_0.0.3 06/18/12 ip=192.168.0.105 latency=0 link=yes multicast=yes port=MII speed=100Mbit/s
resources: irq:26 ioport:2000(size=256) memory:61404000-61404fff memory:61400000-61403fff
*-network DISABLED
description: Wireless interface
product: BCM4313 802.11bgn Wireless Network Adapter
vendor: Broadcom Limited
physical id: 0
bus info: pci@0000:08:00.0
logical name: wlo1
version: 01
serial: e0:06:e6:60:92:d7
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=wl0 driverversion=6.30.223.271 (r587334) latency=0 multicast=yes wireless=IEEE 802.11
resources: irq:17 memory:61500000-61503fff
$ lspci -v
00:00.0 Host bridge: Intel Corporation 3rd Gen Core processor DRAM Controller (rev 09)
Subsystem: Hewlett-Packard Company 3rd Gen Core processor DRAM Controller
Flags: bus master, fast devsel, latency 0
Capabilities: <access denied>
Kernel driver in use: ivb_uncore
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200 v2/3rd Gen Core processor PCI Express Root Port (rev 09) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 24
Bus: primary=00, secondary=01, subordinate=06, sec-latency=0
I/O behind bridge: 00003000-00003fff
Memory behind bridge: 60000000-60ffffff
Prefetchable memory behind bridge: 0000000040000000-000000004fffffff
Kernel driver in use: pcieport
Kernel modules: shpchp
00:02.0 VGA compatible controller: Intel Corporation 3rd Gen Core processor Graphics Controller (rev 09) (prog-if 00 [VGA controller])
Subsystem: Hewlett-Packard Company 3rd Gen Core processor Graphics Controller
Flags: bus master, fast devsel, latency 0, IRQ 29
Memory at 61000000 (64-bit, non-prefetchable) [size=4M]
Memory at 50000000 (64-bit, prefetchable) [size=256M]
I/O ports at 4000 [size=64]
[virtual] Expansion ROM at 000c0000 [disabled] [size=128K]
Kernel driver in use: i915
Kernel modules: i915
00:14.0 USB controller: Intel Corporation 7 Series/C210 Series Chipset Family USB xHCI Host Controller (rev 04) (prog-if 30 [XHCI])
Subsystem: Hewlett-Packard Company 7 Series/C210 Series Chipset Family USB xHCI Host Controller
Flags: bus master, medium devsel, latency 0, IRQ 25
Memory at 61700000 (64-bit, non-prefetchable) [size=64K]
Kernel driver in use: xhci_hcd
00:16.0 Communication controller: Intel Corporation 7 Series/C216 Chipset Family MEI Controller #1 (rev 04)
Subsystem: Hewlett-Packard Company 7 Series/C210 Series Chipset Family MEI Controller
Flags: bus master, fast devsel, latency 0, IRQ 31
Memory at 61714000 (64-bit, non-prefetchable) [size=16]
Kernel driver in use: mei_me
Kernel modules: mei_me
00:1a.0 USB controller: Intel Corporation 7 Series/C216 Chipset Family USB Enhanced Host Controller #2 (rev 04) (prog-if 20 [EHCI])
Subsystem: Hewlett-Packard Company 7 Series/C210 Series Chipset Family USB Enhanced Host Controller
Flags: bus master, medium devsel, latency 0, IRQ 16
Memory at 61719000 (32-bit, non-prefetchable) [size=1K]
Kernel driver in use: ehci-pci
00:1b.0 Audio device: Intel Corporation 7 Series/C216 Chipset Family High Definition Audio Controller (rev 04)
Subsystem: Hewlett-Packard Company 7 Series/C210 Series Chipset Family High Definition Audio Controller
Flags: bus master, fast devsel, latency 0, IRQ 32
Memory at 61710000 (64-bit, non-prefetchable) [size=16K]
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
00:1c.0 PCI bridge: Intel Corporation 7 Series/C216 Chipset Family PCI Express Root Port 1 (rev c4) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 17
Bus: primary=00, secondary=07, subordinate=07, sec-latency=0
I/O behind bridge: 00002000-00002fff
Memory behind bridge: 61600000-616fffff
Prefetchable memory behind bridge: 0000000061400000-00000000614fffff
00:1c.1 PCI bridge: Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 2 (rev c4) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 16
Bus: primary=00, secondary=08, subordinate=08, sec-latency=0
Memory behind bridge: 61500000-615fffff
00:1d.0 USB controller: Intel Corporation 7 Series/C216 Chipset Family USB Enhanced Host Controller #1 (rev 04) (prog-if 20 [EHCI])
Flags: bus master, medium devsel, latency 0, IRQ 20
Memory at 61718000 (32-bit, non-prefetchable) [size=1K]
00:1f.0 ISA bridge: Intel Corporation HM77 Express Chipset LPC Controller (rev 04)
Subsystem: Hewlett-Packard Company HM77 Express Chipset LPC Controller
Kernel driver in use: lpc_ich
Kernel modules: lpc_ich
00:1f.2 RAID bus controller: Intel Corporation 82801 Mobile SATA Controller [RAID mode] (rev 04)
Subsystem: Hewlett-Packard Company 82801 Mobile SATA Controller [RAID mode]
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 28
I/O ports at 4088 [size=8]
I/O ports at 4094 [size=4]
I/O ports at 4080 [size=8]
I/O ports at 4090 [size=4]
I/O ports at 4060 [size=32]
Memory at 61717000 (32-bit, non-prefetchable) [size=2K]
Kernel driver in use: ahci
Kernel modules: ahci
00:1f.3 SMBus: Intel Corporation 7 Series/C216 Chipset Family SMBus Controller (rev 04)
Subsystem: Hewlett-Packard Company 7 Series/C210 Series Chipset Family SMBus Controller
Flags: medium devsel, IRQ 10
Memory at 61715000 (64-bit, non-prefetchable) [size=256]
I/O ports at 4040 [size=32]
Kernel modules: i2c_i801
01:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Thames [Radeon HD 7500M/7600M Series] (rev ff) (prog-if ff)
!!! Unknown header type 7f
Kernel driver in use: radeon
Kernel modules: radeon
07:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTL8411 PCI Express Card Reader (rev 01)
Subsystem: Hewlett-Packard Company RTL8411 PCI Express Card Reader
Flags: bus master, fast devsel, latency 0, IRQ 27
Memory at 61600000 (32-bit, non-prefetchable) [size=64K]
Kernel driver in use: rtsx_pci
Kernel modules: rtsx_pci
07:00.2 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 0a)
DeviceName: Realtek PCIe GBE Family Controller
Subsystem: Hewlett-Packard Company RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
Flags: bus master, fast devsel, latency 0, IRQ 26
I/O ports at 2000 [size=256]
Memory at 61404000 (64-bit, prefetchable) [size=4K]
Memory at 61400000 (64-bit, prefetchable) [size=16K]
Kernel driver in use: r8169
Kernel modules: r8169
08:00.0 Network controller: Broadcom Limited BCM4313 802.11bgn Wireless Network Adapter (rev 01)
Memory at 61500000 (64-bit, non-prefetchable) [size=16K]
