I recently (two weeks ago) installed Chromium in Ubuntu 14.04 LTS using software center. I normally use MATE desktop, installed alongside the default Unity desktop.
After I launch Chromium, the browser stays open for few seconds and then closes.
There was an update few days ago that I hoped would solve the issue, however it did not.
I tried to launch the browser from console. Below is the output I got:
$ chromium-browser
Using PPAPI flash.
 --ppapi-flash-path=/usr/lib/adobe-flashplugin/libpepflashplayer.so --ppapi-flash-version=
Received signal 11 SEGV_MAPERR 000000000010
#0 0x7fa588ef0d47 base::debug::StackTrace::StackTrace()
#1 0x7fa588ef1133 <unknown>
#2 0x7fa588bfe330 <unknown>
#3 0x55cbaeef49f8 <unknown>
#4 0x55cbaeef5fb1 <unknown>
#5 0x55cbaeef6633 <unknown>
#6 0x55cbaeef6bc7 <unknown>
#7 0x7fa588f65b91 <unknown>
#8 0x7fa588ef2269 base::debug::TaskAnnotator::RunTask()
#9 0x7fa588f19040 base::MessageLoop::RunTask()
#10 0x7fa588f1a97d base::MessageLoop::DeferOrRunPendingTask()
#11 0x7fa588f1b79d <unknown>
#12 0x7fa588f1c250 base::MessagePumpLibevent::Run()
#13 0x7fa588f18422 base::MessageLoop::RunHandler()
#14 0x7fa588f40df8 base::RunLoop::Run()
#15 0x7fa588f6ad56 base::Thread::ThreadMain()
#16 0x7fa588f65a96 <unknown>
#17 0x7fa588bf6184 start_thread
#18 0x7fa57f045ffd clone
  r8: 0000000000000000  r9: 0000000000000003 r10: 00007fa511ff9d18 r11: 00007fa57f0d2110
 r12: 00007fa511ff9fe0 r13: 0000000000000008 r14: 0000000000000008 r15: 00007fa511ff9fe0
  di: 0000000000000000  si: 00007fa511ff9fe0  bp: 0000000000000000  bx: 00007fa511ffa0f0
  dx: 00007fa57fb313d8  ax: 00007fa57fb313d8  cx: 0000000000000000  sp: 00007fa511ff9f90
  ip: 000055cbaeef49f8 efl: 0000000000010206 cgf: 0000000000000033 erf: 0000000000000004
 trp: 000000000000000e msk: 0000000000000000 cr2: 0000000000000010
[end of stack trace]
Calling _exit(1). Core file will not be generated.
Zanna
  • 72,312
Asarluhi
  • 1,767
This looks awfully similar to a problem mentioned for 16.04. Does it work if you launch Chromium via chromium-browser --disable-extensions?
Turtle
  • 76
