Laptop: MacbookPro 11,5 with AMD gpu
OS: Lubuntu 17.04
I followed the instruction at https://wiki.archlinux.org/index.php/MacBookPro11,x and it worked.
  1. disable automatic gpu switching in MacOS X (not sure if that helped).
  2. download and compile https://github.com/problame/gmux_backlight
  3. sudo setpci -v -H1 -s 00:01.00 BRIDGE_CONTROL=0
  4. sudo gmux_backlight 120
  5. can adjust brightness with script.
The problem is that
  1. Have to use sudo everytime
  2. The F1/F2 key do not change brightness.
How to fix this?
Update (following terdon's answer)
Moved the compiled gmux_backlight to /usr/sbin/
Used sudo visudo to let each of the user run gmux_backlight with sudo and without entering password.
<username1> ALL=NOPASSWD:/usr/sbin/gmux_backlight
<username2> ALL=NOPASSWD:/usr/sbin/gmux_backlight
<username3> ALL=NOPASSWD:/usr/sbin/gmux_backlight
Create /etc/init.d/gmux_backlight_fix and sudo chmod +x the script.
#!/bin/bash -e
setpci -v -H1 -s 00:01.00 BRIDGE_CONTROL=0 >/dev/null
Symlink the script to run level 2 (the grpahical run level for Ubuntu) with lowest priority (99) by following How to run a script during boot as root.
sudo ln -s /etc/init.d/gmux_backlight_fix /etc/rc2.d/S99gmux_backlight_fix
Added to section of ~/.config/openbox/lubuntu-rc.xml for each user.
<keyboard>
  <chainQuitKey>C-g</chainQuitKey>
  <!-- My Keys -->
  <keybind key="XF86LaunchA">
    <action name="Execute">
      <command>sudo gmux_backlight -10</command>
    </action>
  </keybind>
  <keybind key="XF86LaunchB">
      <command>sudo gmux_backlight +10</command>
    </action>
  </keybind>
I use Fn-F3 and Fn-F4 because Lubuntu can not automatically detect Fn-F1 and Fn-F2 on the laptop.
Initially I wrote a bash script that takes argument and grant every user to run it with sudo. A while later, I worry that people can break the bash script and run any command with sudo privilege. So I use the compiled binary instead of my bash script.
The old bash script is /usr/sbin/gmux_capped_backlight:
#!/bin/bash -e
# setpci
# Get current brightness
CB="$( cat /sys/class/backlight/gmux_backlight/brightness )"
# Split characters of argument
arg=$1
first_char=${arg:0:1}
other_char=${arg:1}
# Desired Brightness
if [ $first_char == "+" ]; then
    Brightness=$(expr $CB + $other_char)
elif [ $first_char == "-" ]; then
    Brightness=$(expr $CB - $other_char)
else
    Brightness=$arg
fi
# Limit the range of brightness #
Max=1024
Min=0
if [ $Brightness -gt $Max ]; then
    Brightness=$Max
fi
if [ $Brightness -lt $Min ]; then
    Brightness=$Min
fi
derHugo
  • 3,376
  • 34
  • 52
Since you say you can already adjust this using a script, it looks like you're almost there already. You just need to:
  1. Set up sudo to allow executing that particular script by your user without a password. First, open a terminal and run sudo visudo. That will bring up a window of your default editor. Add this line to the file:
    terdon  ALL=NOPASSWD:/path/to/your/script
    Obviously, change terdon to your user name and change /path/to/your/script to whatever the path to your script is. It will make your life easier if you can make sure that path has no spaces. Now, save the file and close it.
  2. You can now run the script without needing to enter root's password, so all you need to do is assign the commands to raise and lower brightness to the F1/F2 keys. I don't use LXDE, but I found a forum thread here which suggests you can do it by editing ~/.config/openbox/lxde-rc.xml and adding something like this:
    <keybind key="F2">
        <command>/path/to/your/script increaseBrightness</command>
      </action>
    </keybind>
    <keybind key="F1">
        <command>/path/to/your/script decreaseBrightness</command>
      </action>
    </keybind>
    For both cases, use whatever parameter your script would take to raise/lower the brightness.
    Alternatively, you can also do this by installing xbindkeys:
    sudo apt-get install xbindkeys
    Create the default settings file:
    xbindkeys --defaults > `~/.xbindkeysrc`
    Get the right keycodes for your keys. It will likely be something like F1. Then, edit ~/.xbindkeysrc and add these:
    "/path/to/your/script increaseBrightness"
    F2
    "/path/to/your/script decreaseBrightness"
    F1
    Finally, run xbindkeys and your shortcuts should work. Add it to your list of startup programs so it is always run when you log in.
terdon
  • 104,119
