I have Ubuntu 16.10 but I want to revert back to 16.04 due to some problems. Is there any way to do this without losing all my data?
You can install an older release keeping your /home. It is quite easy.
Boot from an Ubuntu installer, select "Install Ubuntu" and choose "something else" option.
You will be prompted to select partitions where you want to install it. If you don't have a separate /home partition, select the partition where Ubuntu is currently installed.
But don't check the format checkbox.
In this case the installer will re-write the system directories, but will keep /home intact.
It is preferable to enter the same user name and password as you had before.
As aways it is highly recommendable to do a backup first.
If you do have a separate /boot partition, you can tell the system to format / partition, and just use the existing /home.
Be careful if you don't understand the difference!!!
You can downgrade, but to some extent. As Ravexina said above, separate the Ubuntu installation in 2 partitions: 1st) Ubuntu installation (system files), 2nd) Home folder (/home/)
Also, check these links out (they also state the same things I wrote):
1st Link (AskUbuntu question): How to roll back Ubuntu to a previous version?
2nd Link (Ubuntu Help): https://help.ubuntu.com/community/DowngradeHowto
You may want to check this bug: https://bugs.launchpad.net/ubuntu/+source/ubiquity/+bug/891711
- 856
- 1
- 10
- 24
