I have an old laptop. (currently windows 7 is installed)
I would like to use that laptop as my personal server.
Is it possible to boot dual-mode(windows 7 and ubuntu 16.04) in my laptop?
My old laptop is a 64-bit machine and has Intel Pentium CPU (P6200).
Below is main specification of my laptop.
  1. dual core processor(Intel Pentium CPU, 2.1GHz)
  2. 2GB RAM
  3. 64bit machine
  4. 1 HDD(300GB)
1) Is it possible to boot with dual-mode?
2) If it is impossible, then can I install ubuntu 16.04 desktop version?(I will remove windows 7)
newbie16
  • 119
Dual Booting doesn't double requirements
Dual Booting does not mean Windows 7 minimum requirements + Ubuntu minimum requirements = system minimum requirements.
Dual Booting minimum requirements are about 15 GB partition for Ubuntu and common applications. On my 16.04 I give Ubuntu a 30 GB partition out of 880 GB available.
If a Windows version will run a similar Ubuntu version will run
Running Windows 7 with 2 GB ram will be sluggish at times when loading multiple modern web browser pages and videos. The same will happen with a Ubuntu version running similar applications.
As others have mentioned there are scaled down versions of Ubuntu with smaller RAM requirements (starting at about 512 MB I believe) and you would be well served to investigate these versions.
Modest performance improvements
The best improvements to speed you could make on your rig are:
  • Upgrading RAM from 2 GB to 4 GB for about $100.
  • Upgrading 300 GB HDD to 240 GB SSD for about $150.
Note that on some machines upgrading may not be possible depending on system maximum limits.
Yes you can install Ubuntu along with win7 (dual boot)
With only 2 GB of RAM, I recommend installing the lubuntu desktop.
If possible adding another 2GB of RAM would be advantageous.
ravery
  • 6,924
Can you setup dual boot?
Sure, it's not really relevant if the laptop is old, there are no performance drawbacks in dual booting. You will have to create two partitions on your hard drive, so the space you can use on each OS will be limited to e.g. 100 GB for Ubuntu, 200GB for Windows. Here is a guide I have used before.
Single boot instead
If you want to use your laptop as a personal server, why do you want to keep windows? Single booting is less of a hassle to set up, plus you can use the whole hard drive space for Ubuntu.
