 filezilla : Depends: libdbus-1-3 (>= 1.9.14) but 1.6.18-0ubuntu4 is to be installed
             Depends: libfilezilla0 but it is not going to be installed
             Depends: libgnutls30 (>= 3.4.2) but it is not installable
             Depends: libnettle6 but it is not installable
             Depends: libpugixml1v5 (>= 1.7) but it is not installable
             Depends: libstdc++6 (>= 5.2) but 4.8.2-19ubuntu1 is to be installed
             Depends: libwxbase3.0-0v5 (>= 3.0.2+dfsg) but it is not installable
             Depends: libwxgtk3.0-0v5 (>= 3.0.2+dfsg) but it is not installable
How can I fix this?
Zanna
  • 72,312
You can install the package.
make sure the repo sources are up to date
sudo apt-get update
To Install the package:
sudo apt-get install packagename
Once the package determines that you have some missing dependencies, run the following command to fix broken or missing dependencies.
sudo apt-get install -f
Above command will only download the missing dependencies if you have already installed the package.
Shashank
  • 101
