I have tried TeamViewer, AnyDesk, NitroShare and by torrents to transfer my files to a new server. TeamViewer did not connect, NitroShare is for local computers and by torrents does not work because no seeds. I have tried with trackers but also did not work. Since I am desperate because I have 2 hours to migrate the files, I came for help here, if you have any method to transfer
I have also searched for similar questions but all are about local computers I use Ubuntu 16.04
And is a 70GiB folder
Provided you have ssh access to both machines, try rsync.
scp will probably only work when one of the two machines is local. You could ssh into Server1 and
scp -r /your/source/* username@server2:/your/destination/
(or vice versa).
Andyc
  • 228
Have you tried the following?
scp -r username@server1:/path_to_source_directory/* username@server2:/ path_to_the_destination_directory/
mre
