14.04 LTS.
Auto updated, rebooted, bios posts, goes to a black screen with blinking cursor.
Holding shift after Bios post will display the letters GRUB but nothing else.
No other inputs appear to have any effect (tried "alt ->" and "alt<-"; also tried alt+ctrl+f1; and typing my password + enter)
I can still dual boot into Windows.
I can boot into a Live CD but unsure how to fix this.
Last month I had this problem:
After Repairing Deleted Kernel, why would GRUB still not boot into Linux.
I just tried those steps again, shooting in the dark, to no avail.
Please help... What is going on with my Ubuntu install!?
- 56
if you get grub. from a LiveCD. press c to get a command line. change the drive refences as need for your install
From grub type ls (hd0,2)/boot/
you should see a file named vmlinuz or linux, and initrd.img. with version numbers
type: linux (hd0,2)/boot/vmlinuz-#### root=/dev/sda2 or linux (hd0,2)/boot/linux-#### root=/dev/sda2 depending on what you found with ls (hd0,1)/ then
`initrd (hd0,2)/boot/initrd-#####.img`
boot
if you get initramfs rescue mode -- enter your password then startx you should now have a desktop.
use gparted to check your file system, if it reports an error, then you need to boot from a LiveCD or other media to fix it .... DO NOT attempt to repair a mounted partition.
The following three commands fix many grub boot problems. They run quick so just do all three instead of trying to find which one you need.
sudo install-grub /dev/sda, sudo update-grub and sudo update-initramfs -u
reboot and see what you get
- 6,924
