I own a server at my Parents house and recently there has been a lot of power cuts and when our Router comes back online it changes its Public/Global IP address which makes me unable to connect to it (SSH, FTP, HTTP) ,is there any way that I could make a script that when the power goes out on my server and it reboots it send an email with my Global/Public IP to me.
You could try using sendmail. install
sudo apt install -y postfix
choose internet side and enter your server's hostname
Write a script e.g. in sudo nano /usr/local/bin/sendIPmail:
#!/bin/bash
# 1. gets the primary IP
#from https://stackoverflow.com/a/25851186/7111561
IP=$( ip route get 1 | awk '{print $NF;exit}' )
# 2. send it using sendmail
#from https://stackoverflow.com/a/13390926/7111561
#--- adjust those ---
recipients="your.mail@address,another@mail.address"
subject="some subject"
from="info@your.server"
/usr/sbin/sendmail "$recipients" <<EOF
subject:$subject
New IP is $IP
EOF
exit 0
make it executable
sudo chmod +x /usr/local/bin/sendIPmail
and call it on every reboot run
sudo crontab -e
(select your editor e.g. 2 for nano) Add the line
@reboot /usr/local/bin/sendIPmail
This does not require any external webpages or complex scripts/setups and uses only packages from the official Ubuntu repos.
NOTE: Alternatively you really should consider using a static IP address for a server!
- 3,376
- 5
- 34
- 52
use my script.
- Clone the script from my github repo:
git clone https://github.com/el-beth/sendExternalIPAddress.git
- then move the
sendexternalip.bashfile from the directorysendExternalIPAddressto/usr/lib- use the following command to do so.
sudo cp sendExternalIPAddress/sendexternalip.bash /usr/lib
- now make the script executable:
sudo chmod +x /usr/lib/sendexternalip.bash
for the first time, to install all the necessary packages and dependencies:
sudo /usr/lib/sendexternalip.bashnow to make the script run automatically on startup run the following command:
sudo printf "start on startup\ntask\nexec /us/lib/sendexternalip.bash\n" > ~/.config/upstart/sendexternalip.conf
This will make your Linux box email it's current external IP address to the email address specified in the script.
N.B. The script - by default - sends the External IP address to the email address "receiver@grr.la", however, you can change the customReceiverEmail variable on line 9 of the script to any @grr.la address of you choosing and the IP address will be sent to that address instead.
- 637
