A few weeks ago, Gimp was working fine, then I tried to open it, the icon flashes away a bit, and then closes again, one time there appeared a dialog which told me that Gimp had unexpectedly closed, and I could choose wether I wanted to restart the program or leave it closed. Restarting had no effect.
Then I started Gimp via terminal, and got this output:
(gimp:26651): GLib-GObject-WARNING **: g_object_set_valist: object class 'GeglConfig' has no property named 'cache-size'
(gimp:26651): GEGL-gegl-operation.c-WARNING **: Cannot change name of operation class 0x178E180 from "gimp:point-layer-mode" to "gimp:dissolve-mode"
(gimp:26651): GEGL-gegl-operation.c-WARNING **: Cannot change name of operation class 0x178E650 from "gimp:point-layer-mode" to "gimp:behind-mode"
(gimp:26651): GEGL-gegl-operation.c-WARNING **: Cannot change name of operation class 0x178EE90 from "gimp:point-layer-mode" to "gimp:multiply-mode"
(gimp:26651): GEGL-gegl-operation.c-WARNING **: Cannot change name of operation class 0x178F1A0 from "gimp:point-layer-mode" to "gimp:screen-mode"
(gimp:26651): GEGL-gegl-operation.c-WARNING **: Cannot change name of operation class 0x178F570 from "gimp:point-layer-mode" to "gimp:overlay-mode"
(gimp:26651): GEGL-gegl-operation.c-WARNING **: Cannot change name of operation class 0x178F9A0 from "gimp:point-layer-mode" to "gimp:difference-mode"
(gimp:26651): GEGL-gegl-operation.c-WARNING **: Cannot change name of operation class 0x178FD60 from "gimp:point-layer-mode" to "gimp:addition-mode"
(gimp:26651): GEGL-gegl-operation.c-WARNING **: Cannot change name of operation class 0x1790130 from "gimp:point-layer-mode" to "gimp:subtract-mode"
(gimp:26651): GEGL-gegl-operation.c-WARNING **: Cannot change name of operation class 0x17904F0 from "gimp:point-layer-mode" to "gimp:darken-only-mode"
(gimp:26651): GEGL-gegl-operation.c-WARNING **: Cannot change name of operation class 0x1790940 from "gimp:point-layer-mode" to "gimp:lighten-only-mode"
(gimp:26651): GEGL-gegl-operation.c-WARNING **: Cannot change name of operation class 0x1790D50 from "gimp:point-layer-mode" to "gimp:hue-mode"
(gimp:26651): GEGL-gegl-operation.c-WARNING **: Cannot change name of operation class 0x1791080 from "gimp:point-layer-mode" to "gimp:saturation-mode"
(gimp:26651): GEGL-gegl-operation.c-WARNING **: Cannot change name of operation class 0x17914E0 from "gimp:point-layer-mode" to "gimp:color-mode"
(gimp:26651): GEGL-gegl-operation.c-WARNING **: Cannot change name of operation class 0x1791950 from "gimp:point-layer-mode" to "gimp:value-mode"
(gimp:26651): GEGL-gegl-operation.c-WARNING **: Cannot change name of operation class 0x17920F0 from "gimp:point-layer-mode" to "gimp:divide-mode"
(gimp:26651): GEGL-gegl-operation.c-WARNING **: Cannot change name of operation class 0x1792570 from "gimp:point-layer-mode" to "gimp:dodge-mode"
(gimp:26651): GEGL-gegl-operation.c-WARNING **: Cannot change name of operation class 0x17928E0 from "gimp:point-layer-mode" to "gimp:burn-mode"
(gimp:26651): GEGL-gegl-operation.c-WARNING **: Cannot change name of operation class 0x1792D30 from "gimp:point-layer-mode" to "gimp:hardlight-mode"
(gimp:26651): GEGL-gegl-operation.c-WARNING **: Cannot change name of operation class 0x17930D0 from "gimp:point-layer-mode" to "gimp:softlight-mode"
(gimp:26651): GEGL-gegl-operation.c-WARNING **: Cannot change name of operation class 0x17934D0 from "gimp:point-layer-mode" to "gimp:grain-extract-mode"
(gimp:26651): GEGL-gegl-operation.c-WARNING **: Cannot change name of operation class 0x1793930 from "gimp:point-layer-mode" to "gimp:grain-merge-mode"
(gimp:26651): GEGL-gegl-operation.c-WARNING **: Cannot change name of operation class 0x1793CE0 from "gimp:point-layer-mode" to "gimp:color-erase-mode"
(gimp:26651): GEGL-gegl-operation.c-WARNING **: Cannot change name of operation class 0x17940D0 from "gimp:point-layer-mode" to "gimp:erase-mode"
(gimp:26651): GEGL-gegl-operation.c-WARNING **: Cannot change name of operation class 0x17944F0 from "gimp:point-layer-mode" to "gimp:replace-mode"
(gimp:26651): GEGL-gegl-operation.c-WARNING **: Cannot change name of operation class 0x17948C0 from "gimp:point-layer-mode" to "gimp:anti-erase-mode"
/home/peter/.gimp-2.8/themes/Darker GIMP_Orange small/imagerc:5258: Kan afbeelding in pixmap_pad: ‘../Decor/icons/GIMP_Orange/dialogs/stock-image-16.png’ niet vinden
/home/peter/.gimp-2.8/themes/Darker GIMP_Orange small/imagerc:5259: Kan afbeelding in pixmap_pad: ‘../Decor/icons/GIMP_Orange/dialogs/stock-image-16.png’ niet vinden
/home/peter/.gimp-2.8/themes/Darker GIMP_Orange small/imagerc:5260: Kan afbeelding in pixmap_pad: ‘../Decor/icons/Dark/dialogs/stock-image-16.png’ niet vinden
/home/peter/.gimp-2.8/themes/Darker GIMP_Orange small/imagerc:5261: Kan afbeelding in pixmap_pad: ‘../Decor/icons/Dark/dialogs/stock-image-16.png’ niet vinden
/home/peter/.gimp-2.8/themes/Darker GIMP_Orange small/imagerc:5262: Kan afbeelding in pixmap_pad: ‘../Decor/icons/Dark/dialogs/stock-image-16.png’ niet vinden
/home/peter/.gimp-2.8/themes/Darker GIMP_Orange small/imagerc:5265: Kan afbeelding in pixmap_pad: ‘../Decor/icons/GIMP_Orange/dialogs/stock-image-16.png’ niet vinden
/home/peter/.gimp-2.8/themes/Darker GIMP_Orange small/imagerc:5266: Kan afbeelding in pixmap_pad: ‘../Decor/icons/GIMP_Orange/dialogs/stock-image-16.png’ niet vinden
/home/peter/.gimp-2.8/themes/Darker GIMP_Orange small/imagerc:5267: Kan afbeelding in pixmap_pad: ‘../Decor/icons/Dark/dialogs/stock-image-16.png’ niet vinden
/home/peter/.gimp-2.8/themes/Darker GIMP_Orange small/imagerc:5268: Kan afbeelding in pixmap_pad: ‘../Decor/icons/Dark/dialogs/stock-image-16.png’ niet vinden
/home/peter/.gimp-2.8/themes/Darker GIMP_Orange small/imagerc:5269: Kan afbeelding in pixmap_pad: ‘../Decor/icons/Dark/dialogs/stock-image-16.png’ niet vinden
/home/peter/.gimp-2.8/themes/Darker GIMP_Orange small/imagerc:5272: Kan afbeelding in pixmap_pad: ‘../Decor/icons/GIMP_Orange/dialogs/stock-image-16.png’ niet vinden
/home/peter/.gimp-2.8/themes/Darker GIMP_Orange small/imagerc:5273: Kan afbeelding in pixmap_pad: ‘../Decor/icons/GIMP_Orange/dialogs/stock-image-16.png’ niet vinden
/home/peter/.gimp-2.8/themes/Darker GIMP_Orange small/imagerc:5274: Kan afbeelding in pixmap_pad: ‘../Decor/icons/Dark/dialogs/stock-image-16.png’ niet vinden
/home/peter/.gimp-2.8/themes/Darker GIMP_Orange small/imagerc:5275: Kan afbeelding in pixmap_pad: ‘../Decor/icons/Dark/dialogs/stock-image-16.png’ niet vinden
/home/peter/.gimp-2.8/themes/Darker GIMP_Orange small/imagerc:5276: Kan afbeelding in pixmap_pad: ‘../Decor/icons/Dark/dialogs/stock-image-16.png’ niet vinden
/home/peter/.gimp-2.8/themes/Darker GIMP_Orange small/imagerc:5279: Kan afbeelding in pixmap_pad: ‘../Decor/icons/Dark/dialogs/stock-image-16.png’ niet vinden
Segmentatiefout (geheugendump gemaakt)
The last half are errors from a theme I had installed.
I have tried reinstalling, purging the installation via terminal and via Synaptic, but I still get the same result.
Running Ubuntu 16.04 LTS
