Using the instructions on "https://www.foxitsoftware.com/pdf-reader/" I downloaded the software and followed the instructions. On the last step I got message: " cannot execute binary file: Exec format error" I selected the 64 bit download. I have also tried other instructions for older Foxit Reader versions, all gave same problem.
Please follow the steps below to install Foxit Reader for Linux:
  •   Change to the directory containing the downloaded
      file (used /tmp as the example):
      # cd /tmp
  •   Uncompress the executable
      # gzip -d 'FoxitReader_version_Setup.run.tar.gz'
  •   Untar the .tar file:
      # tar xvf 'FoxitReader_version_Setup.run.tar'
  •   Run the installer:
      # ./'FoxitReader_version_Setup.run'  ***Error on this step***
  •   Follow the steps on the screen to complete the
      installation
Added Here is print out of terminal session.
bob@bob-PORTEGE-Z30-B:~$ cd Downloads
bob@bob-PORTEGE-Z30-B:~/Downloads$ ls
FoxitReader2.4.1.0609_Server_x64_enu_Setup.run.tar.gz
linux-brprinter-installer-2.0.0-1.gz
mfcj885dwcupswrapper-1.0.0-0.i386.deb
mfcj885dwlpr-1.0.0-0.i386.deb
bob@bob-PORTEGE-Z30-B:~/Downloads$ gzip -d 'FoxitReader2.4.1.0609_Server_x64_enu_Setup.run.tar.gz'
bob@bob-PORTEGE-Z30-B:~/Downloads$ tar xvf 'FoxitReader2.4.1.0609_Server_x64_enu_Setup.run.tar'
FoxitReader.enu.setup.2.4.1.0609(r08f07f8).x64.run
bob@bob-PORTEGE-Z30-B:~/Downloads$ ./'FoxitReader.enu.setup.2.4.1.0609(r08f07f8).x64.run'
bash: ./FoxitReader.enu.setup.2.4.1.0609(r08f07f8).x64.run: cannot execute binary file: Exec format error
Problem resolved - was trying to install 64bit software on 32 bit ubuntu. Note: the hardware, BIOS, says it is 64 but ubuntu says 32.
muru
  • 207,228
If you typed the instructions exactly as shown in your question, you will fail. Foxit Reader expects that you will replace "version" with the version number of the file that you have downloaded. Try the following:
In a terminal, change to the directory that has the downloaded file you want to install. Please make sure that there is only one version of the Foxit software in the directory...
Enter gzip -d Foxit then press tab, and enter - no space between the t and tab. This should complete the command with the name of the gz file.
Enter tar xvf Foxit then press tab, and enter - this should complete the command with the name of the tar file.
Enter ./Foxit then press tab, and enter - this should complete the command with the name of the executable file.
Charles Green
  • 21,859
