I can't install any package even dpkg my dpkg file's and folders has been deleted and I received this error:
Could not exec dpkg!
E: Sub-process /usr/bin/dpkg returned an error code (100)
EDIT: When I ran sudo apt-get update && sudo apt-get install --reinstall dpkg I got this output:
dpkg: warning: 'dpkg-deb' not found in PATH or not executable.
dpkg: error: 1 expected program not found in PATH or not executable.
Note: root's PATH should usually contain /usr/local/sbin, /usr/sbin and /sbin.
E: Sub-process /usr/bin/dpkg returned an error code (2)
EDIT
When install buddgie desktop
 budgie-desktop-environment : Depends: budgie-lightdm-theme (>= 0.5.4) but it is not going to be installed
                          Depends: plymouth-themes but it is not installable
                          Recommends: arc-firefox-theme but it is not going to be installed
                          Recommends: pocillo-icon-theme but it is not going to be installed
                          Recommends: budgie-indicator-applet but it is not going to be installed
                          Recommends: vertex-theme but it is not going to be installed
                          Recommends: gthumb but it is not installable
                          Recommends: rhythmbox-plugin-alternative-toolbar but it is not installable
                          Recommends: menulibre but it is not installable
                          Recommends: transmission but it is not installable
                          Recommends: tlp but it is not installable
                          Recommends: budgie-welcome but it is not going to be installed
Sina hy
You might want to reinstall dpkg by doing the following:
sudo -i
mkdir /tmp/dpkg
cd /tmp/dpkg
Mind that you might want to look whether the download links are still up-too-date
If you are running a 32 bit version of ubuntu
wget http://security.ubuntu.com/ubuntu/pool/main/d/dpkg/dpkg_1.17.5ubuntu5.2_i386.deb
For 64 bit
wget http://security.ubuntu.com/ubuntu/pool/main/d/dpkg/dpkg_1.17.5ubuntu5.7_amd64.deb
then
ar x dpkg*.deb data.tar.gz
tar xfvz data.tar.gz ./usr/bin/dpkg
Now copy the binary to /usr/bin with
sudo cp ./usr/bin/dpkg /usr/bin
And finally run
sudo apt-get update
ADDB
  • 1,608
