First of all, I checked this, this, this, and this threads and neither the solutions nor the problems themselves correspond exactly to my issue.
The setup in which my issue occurs:
GPU: NVIDIA GeForce GTX 1050.
Ubuntu: 16.04 LTS.
The issue:
After installing NVIDIA's drivers (NVIDIA-Linux-x86_64-375.20) everything works just fine. However, out of the blue, every 7~10 days, I will get a login loop that forces me to purge drivers, stop lightdm, re-install, and reboot. This works every single time, so the issue has a solution but it keeps happening every other week.
Measures taken:
So far the only measure I have adopted is including nomodeset to my Grub. I thought this would fix the issue but since I included it the problem occurred twice (so that means I included nomodeset like a month ago).
The fact that the issue happens periodically makes me think that it is related to some process that also occurs every other week. I might be wrong, but I just wanted to check with the community as I am a Linux aficionado and not an expert in any way.
Any lead/idea/suggestion will be very appreciated. Thanks!
YSC
I'm sorry to say this, but I think you should escalate this to your Gfx card's warranty division. It is always surprising what a single semi failed transistor can do.
