Everything that depends on the lsb_release command is not working on my computer.
example:
pip install numpy
raise subprocess.CalledProcessError(code, cmd, stdout, stderr) subprocess.CalledProcessError: Command 'lsb_release -a' returned non-zero exit status 1
And in fact, lsb_release -a generates an error
File "/usr/bin/lsb_release", line 95, in <module>
main()
File "/usr/bin/lsb_release", line 59, in main
distinfo = lsb_release.get_distro_information()
File "/usr/lib/python3/dist-packages/lsb_release.py", line 383, in get_distro_information
distinfo = guess_debian_release()
File "/usr/lib/python3/dist-packages/lsb_release.py", line 281, in guess_debian_release
get_distro_info(distinfo['ID'])
File "/usr/lib/python3/dist-packages/lsb_release.py", line 41, in get_distro_info
RELEASES_ORDER.sort(key=lambda n: float(n[0]))
File "/usr/lib/python3/dist-packages/lsb_release.py", line 41, in <lambda>
ValueError: could not convert string to float: '8.04 LTS'
I know that in python '8.04 LTS' cannot be converted to a float, but why is this happening.
I've tried to reinstall both lsb_release and python-pip but this does not fix the problem.
I'm on Ubuntu 16.04 LTS.
any help ?
