13
I have run into a problem installing mssql server (ver. 14.0.600) on an Ubuntu server (16.04, x86-64). The installation stops with the following error:
mssql-server : Depends: openssl (<= 1.1.0).
However, apt-cache policy openssl reports openssl as:
Installed: 1.1.0f-2~ubuntu16.04.1+deb.sury.org+1 /
Candidate: 1.1.0f-2~ubuntu16.04.1+deb.sury.org+4
sudo apt-get install -f was initially: 0 upgraded, 0 newly installed, 0 to remove and 7 not upgraded. After apt-get upgrade (apache,openssl,grub): 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Sadly enough, same dependency error as before.
Is openssl 1.1.0f > 1.1.0 ? Is there any way out of this problem, short of reinstalling Ubuntu with openssl 1.0.2g ?
Trying to downgrade openssl does not appear to be a safe procedure according to several posts on the net.
Edit: apt-get purge --auto-remove openssl returns 0 upgraded, 0 newly installed, 139 to remove and 0 not upgraded. This is not something that I want to/dare to do right now.
christerk
  • 141
I have the same problem after update openssl, try this
  1. Install aptitute sudo apt install aptitude
  2. sudo aptitude install mssql-server
The following NEW packages will be installed: ... The following packages have unmet dependencies: mssql-server : Depends: openssl (<= 1.1.0) but 1.1.0f-2~ubuntu16.04.1+deb.sury.org+1 is installed. The following actions will resolve these dependencies:
Keep the following packages at their current version:
        1)  mssql-server [Not Installed]
Accept this solution? [Y/n/q/?] n
  1. type n and press enter
Downgrade the following packages:
        1)  openssl [1.1.0f-2~ubuntu16.04.1+deb.sury.org+1 (now) -> 1.0.2g-1ubuntu4.6 (xenial-security)]
Accept this solution? [Y/n/q/?] Y The following packages will be DOWNGRADED: openssl
  1. type Y and press enter, and mssql-server will be installed
  2. sudo /opt/mssql/bin/mssql-conf setup
re-configure your installation
luiarhs
  • 141
12
Apparent solution for Ubuntu 18.04:
apt-get install -y libjemalloc1 libsss-nss-idmap0 libc++1 gawk curl
curl https://packages.microsoft.com/keys/microsoft.asc | apt-key add -
add-apt-repository "$(curl https://packages.microsoft.com/config/ubuntu/16.04/mssql-server-2017.list)"
add-apt-repository "$(curl https://packages.microsoft.com/config/ubuntu/16.04/prod.list)"
wget http://archive.ubuntu.com/ubuntu/pool/main/c/ca-certificates/ca-certificates_20160104ubuntu1_all.deb
dpkg -i ca-certificates_20160104ubuntu1_all.deb
wget http://archive.ubuntu.com/ubuntu/pool/main/o/openssl/openssl_1.0.2g-1ubuntu4_amd64.deb
dpkg -i openssl_1.0.2g-1ubuntu4_amd64.deb
apt install -y libcurl3
apt-get update
apt-get install -y mssql-server
It is necessary to check if SQL subsequently works well without problems.
Melebius
  • 11,750
