I know the command for moving up one directory is cd ..
Is there any command to move down one directory?
Yaron
  • 13,453
6 Answers6
15
The main difference between moving up a directory, and moving down a directory, in the directory tree is:
  • Moving up - there is only one option, hence the command doesn't need to mention the folder name:
    cd ..
  • Moving down - there might be several sub-directories, hence you first need to choose sub-directory, to change directory down into example-dir the command is:
    cd example-dir
Yaron
  • 13,453
13
In older versions of bash (e.g: 4.3) you could do cd * and it would go to the first sub directory it found:
$ ls
dir1/   dir2/   dir3/
$ cd *
Now we are in dir1/.
Ravexina
  • 57,256
The way by which you want to go down by one directory is not possible because there is only one parent directory which is denoted by .., but there can be multiple directories inside a directory and thus you have to mention the one you mean. You have to use cd example to move down by one onto the directory example.
But there is a shortcut: use Tab completion for this. To move down by one into the example directory, you could enter cd e and press Tab and if example is the only directory beginning with e the shell will automatically complete the command to cd example. If there are others beginning with e, double Tab will list matches, and you can type ex or whatever is needed and press Tab again and so on.
Zanna
  • 72,312
You can move up cause because there is one directory but when we talk about going down there can be more than one that is why we have ls we will list all the available directory and then we change directory one down in which we needed to go by the command cd examle1.
$ ls
dir1 dir2 sir3
$ cd dir1
$ cd ..
$ cd dir2
And so on.
wjandrea
  • 14,504
cdd is a small bash script that's a power tool for the cd command. Visit the link below for a one minute video and copy the code below if you like what you see.
cdd - a Change Directory (cd) Power Tool
It's annoying have to type out long sub-directory names with spaces. So I created a little function in ~/.bashrc that automatically changes down one sub-directory level if there is only one sub-directory. If there is more than one sub-directory then zenity is used to pick one to change to.
cdd () {
OFS="$IFS"                                  # Save Input File Separator
IFS=$'\n'
# Bash array of directories names
dirs=( $(find . -maxdepth 1 -type d | grep './' | cut -c 3- | sort) )
# If no directories exit
if [ "${#dirs}" -eq 0 ] ; then
    echo "No subdirectories"
    IFS="$OFS"                              # Restore Input File Separator
    return
fi
# Only one directory then change to it and exit
if [ "${#dirs[@]}" -eq 1 ] ; then
    cd "${dirs[0]}"
    return
fi
# Zenity to pick one of the directories
result=$(zenity --list --width=600 --height=400 --title="down" \
         --column="Sub-Directories" "${dirs[@]}" \
         2> >(grep -v 'GtkDialog' >&2))     # Suppress Gtk annoying message
if [ ! -z "$result" ] ; then                # Did they select an item?
    cd "$result"
fi
Copy above code into your ~/.bashrc file and then open a terminal and type cdd to use it.
If terminal is already open, you can resource your revised ~/.bashrc file with:
source ~/.bashrc
or
. ~/.bashrc
Usage
When you call cdd and there is more than one sub-directory you need to pick one:
In this screen if you click OK button it is equivalent to:
cd Seven\ Mary\ Three
or:
cd "Seven Mary Three"
When you call cdd and there is only one sub-directory it automatically changes to it:
rick@alien:~/Music/Seven Mary Three$ cdd
rick@alien:~/Music/Seven Mary Three/American Standard$
When you call cdd and there are no sub-directories an error is displayed:
rick@alien:~/Music/Seven Mary Three/American Standard$ cdd
No subdirectories
This doesn't answer exactly the question that was asked, but as was pointed out by someone else, that question didn't really make sense anyway.
But here is the answer to a nearby question. To go back to the directory from whence you came, use cd -
[mike@gwydion Work]$ cd ..
[mike@gwydion ~]$ cd -
/home/mike/Work
If you want to save a directory for later reference, do some stuff in between in a bunch of other directories, and then go back, use pushd and popd:
[mike@gwydion Work]$ pushd .
~/Work ~/Work
[mike@gwydion Work]$ cd ~/Temp/
[mike@gwydion Temp]$ run some command
[mike@gwydion Temp]$ cd ~/SourceCode/
[mike@gwydion SourceCode]$ run some command
[mike@gwydion SourceCode]$ popd
~/Work
[mike@gwydion Work]$ popd
bash: popd: directory stack empty
