So I just installed Ubuntu and my Wacom tablet isn't detected by system settings. My tablet is a Wacom Intuos draw. Except that everything works I just needed the system settings to work so I could map it to monitor so it has the same aspect ratio. Like right now when I draw circle it draws ovals I think you know what I mean. I tried this command: xsetwacom -v set "Wacom Intuos S 2 Pen stylus" MapToOutput VGA-0 and nothing changed this is what I got in the terminal:
... Display is '(null)'.
... 'set' requested for 'Wacom Intuos S 2 Pen stylus'.
... Checking device 'Virtual core pointer' (2).
... Checking device 'Virtual core keyboard' (3).
... Checking device 'Virtual core XTEST pointer' (4).
... Checking device 'Virtual core XTEST keyboard' (5).
... Checking device 'Power Button' (6).
... Checking device 'Power Button' (7).
... Checking device 'Microsoft Wired Keyboard 600' (10).
... Checking device 'Microsoft Wired Keyboard 600' (11).
... Checking device 'Microsoft Wired Keyboard 600' (12).
... Checking device 'Wacom Intuos S 2 Pen stylus' (8).
... Checking device 'Wacom Intuos S 2 Pad pad' (9).
... Device 'Wacom Intuos S 2 Pen stylus' (8) found.
... Found output 'HDMI-0' (disconnnected)
... Found output 'VGA-0' (connected)
... CRTC (0x0) 1280x1024
... Setting CRTC VGA-0
... Remapping to output area 1280x1024 @ 0,0.
... Transformation matrix:
... [ 1.000000 0.000000 0.000000 ]
... [ 0.000000 1.000000 0.000000 ]
... [ 0.000000 0.000000 1.000000 ]
Also I had Debian 9 before and the settings worked with no problems on the GNOME Desktop.
Update: I managed to map to area but now I need to find which number should work on my resolution (1280x1024) the number I currently have for the area is 0 0 15200 9500
