so i have a computer i am trying to set up as a server at home. i have ssh server installed on it, and ssh client running on my laptop. ssh works fine, i am using public keys for security and have passwords disabled.
i do not have a static ip address, so i have gotten a domain name, will refer to it as domain.online in following, i got this through namecheap. i am running ubuntu server on the home server, and ubuntu on my laptop. i have configured ddclient according to the documentation on namecheap and the official ubuntu documentation on DynamicDNS.
i spoke with representatives from namecheap whom confirmed i have the nameservers set up correctly. but when i attempt to ssh into the server by;
ssh username@domain.online
i am given a;
connect to host domain.online port 22: connection refused
i have enabled port forwarding on my router. i am currently ssh'd into the server remotely at this moment, so port forwarding is working. (i called my wife and had her look up the ip address at whatsmyip).
also UFW is disabled.
the following is my ddclient.conf file;
es# Configuration file for ddclient generated by debconf
# /etc/ddclient.conf
#pid=/var/run/ddclient.pid
#use=if, if=enp2s0f0
use=web, web=dynamicdns.park-your-domain.com/getip
protocol=namecheap
#ssl=yes
server=dynamicdns.park-your-domain.com
login=domain.online
password=################
www
and the following is from my sshd_config file;
# $OpenBSD: sshd_config,v 1.100 2016/08/15 12:32:04 naddy Exp $
# This is the sshd server system-wide configuration file. See
# sshd_config(5) for more information.
# This sshd was compiled with PATH=/usr/bin:/bin:/usr/sbin:/sbin
# The strategy used for options in the default sshd_config shipped with
# OpenSSH is to specify options with their default value where
# possible, but leave them commented. Uncommented options override the
# default value.
#Port 22
#AddressFamily any
#ListenAddress 0.0.0.0
#ListenAddress ::
#HostKey /etc/ssh/ssh_host_rsa_key
#HostKey /etc/ssh/ssh_host_ecdsa_key
#HostKey /etc/ssh/ssh_host_ed25519_key
# Ciphers and keying
#RekeyLimit default none
# Logging
#SyslogFacility AUTH
#LogLevel INFO
# Authentication:
#LoginGraceTime 2m
#PermitRootLogin prohibit-password
#StrictModes yes
#MaxAuthTries 6
#MaxSessions 10
PubkeyAuthentication yes
RSAAuthentication yes
# Expect .ssh/authorized_keys2 to be disregarded by default in future.
AuthorizedKeysFile .ssh/authorized_keys .ssh/authorized_keys2
#AuthorizedPrincipalsFile none
#AuthorizedKeysCommand none
#AuthorizedKeysCommandUser nobody
# For this to work you will also need host keys in /etc/ssh/ssh_known_hosts
#HostbasedAuthentication no
# Change to yes if you don't trust ~/.ssh/known_hosts for
# HostbasedAuthentication
#IgnoreUserKnownHosts no
# Don't read the user's ~/.rhosts and ~/.shosts files
#IgnoreRhosts yes
# To disable tunneled clear text passwords, change to no here!
PasswordAuthentication no
#PermitEmptyPasswords no
# Change to yes to enable challenge-response passwords (beware issues with
# some PAM modules and threads)
ChallengeResponseAuthentication no
# Kerberos options
#KerberosAuthentication no
#KerberosOrLocalPasswd yes
#KerberosTicketCleanup yes
#KerberosGetAFSToken no
# GSSAPI options
#GSSAPIAuthentication no
#GSSAPICleanupCredentials yes
#GSSAPIStrictAcceptorCheck yes
#GSSAPIKeyExchange no
# Set this to 'yes' to enable PAM authentication, account processing,
# and session processing. If this is enabled, PAM authentication will
# be allowed through the ChallengeResponseAuthentication and
# PasswordAuthentication. Depending on your PAM configuration,
# PAM authentication via ChallengeResponseAuthentication may bypass
# the setting of "PermitRootLogin without-password".
# If you just want the PAM account and session checks to run without
# PAM authentication, then enable this but set PasswordAuthentication
# and ChallengeResponseAuthentication to 'no'.
UsePAM yes
#AllowAgentForwarding yes
AllowTcpForwarding yes
#GatewayPorts no
X11Forwarding yes
#X11DisplayOffset 10
#X11UseLocalhost yes
#PermitTTY yes
PrintMotd no
#PrintLastLog yes
#TCPKeepAlive yes
#UseLogin no
#UsePrivilegeSeparation sandbox
#PermitUserEnvironment no
#Compression delayed
#ClientAliveInterval 0
#ClientAliveCountMax 3
#UseDNS no
#PidFile /var/run/sshd.pid
#MaxStartups 10:30:100
#PermitTunnel no
#ChrootDirectory none
#VersionAddendum none
# no default banner path
#Banner none
# Allow client to pass locale environment variables
AcceptEnv LANG LC_*
# override default of no subsystems
Subsystem sftp /usr/lib/openssh/sftp-server
# Example of overriding settings on a per-user basis
#Match User anoncvs
# X11Forwarding no
# AllowTcpForwarding no
# PermitTTY no
# ForceCommand cvs server
i dont know if that file is neccesary, but i figured someone would ask for it
so, again, my question is why when i type
i get the connection refused error, but when i
ssh username@00.00.00.00
i connect succesfully to my server.
additionally, the results of sudo service ddclient status is:
ddclient.service - LSB: Update dynamic domain name service entries
Loaded: loaded (/etc/init.d/ddclient; generated; vendor preset: enabled)
Active: active (running) since Tue 2017-06-27 14:21:21 EDT; 23h ago
Docs: man:systemd-sysv-generator(8)
Tasks: 1 (limit: 4915)
Memory: 8.7M
CPU: 5.581s
CGroup: /system.slice/ddclient.service
└─7217 ddclient - sleeping for 10 seconds
Jun 27 14:21:20 computer-name systemd[1]: Starting LSB: Update dynamic domai
Jun 27 14:21:21 computer-name systemd[1]: Started LSB: Update dynamic domain
lines 1-12/12 (END)
