I'm running sudo apt-get update to update a new install on Ubuntu 16.04.2 64 bit. I get the following error message:
The repository 'cdrom://Ubuntu 16.04.2 LTS _Xenial Xerus_ - Release amd64 (20170215.2) xenial Release' does not have a Release file.
N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use.
N: See apt-secure(8) manpage for repository creation and user configuration details.
E: Failed to fetch cdrom://Ubuntu 16.04.2 LTS _Xenial Xerus_ - Release amd64 (20170215.2)/dists/xenial/main/binary-amd64/Packages  Please use apt-cdrom to make this CD-ROM recognized by APT. apt-get update cannot be used to add new CD-ROMs
E: Some index files failed to download. They have been ignored, or old ones used instead.
I tried using the apt-cdrom command to mount the cdrom but it seems to not work, I think i'm typing it in wrong as i am new to linux and have only been using it for a few weeks.I try to type in commands and it comes back as command cannot be found.the apt-cdrom has great info on how to probably solve this problem but I'm not sure how to use it or how to properly type the commands in.
Stormlord
  • 6,807
Lou M
Do you have the installer CD loaded? It appears your /etc/apt/sources.list might think you do, and hence the angry errors.
What does the command cat /etc/apt/sources.list show you? In particular, is the line that starts with deb cdrom commented out (has a # prepended to it)? If not, it should be (assuming you don't have the CD loaded).
And remember that any changes to /etc/apt/sources.list requires a refresh (sudo apt-get update).
More details about managing Ubuntu repositories here: https://help.ubuntu.com/community/Repositories/CommandLine
richbl
  • 2,373
