VirtualBox 5.1.22, installed extension pack 5.1.22 Win10 host Ubuntu 16.04 guest, installed 5.1.22 of VirtualBox Guest Additions
Under settings have checked Enable USB Controller, selected USB 2.0 (EHCI) and added my FTDI Quad RS232-HS [0800] filter.
I start Ubuntu. Connect my device. I see my four USB /dev/ttyUSB# serial ports. I can use them just fine.
The problem comes if I remove my USB cable and then re-connect it. When I remove the USB, the ttyUSBs go away as expected. I reconnect the USB cable and the ttyUSBs do not get recreated. I need to restart Ubuntu to get the ports to return.
I have the same VM machine hosted on Win7 under the same VBox configuration and it works. I can connect and reconnect the USB cable over and over and the terminal ports are always recreated.
I tried creating a new Ubuntu guest from scratch (rather than copying the existing one from my Win7 system) and the newly created one has the same problem.
I notice on my Win10 device manager that the Comm Ports are not returned after shutting down Ubuntu.
I'm not sure how to approach solving this issue; is it a hardware issue, a configuration issue with Ubuntu, VB or Win10?! Not sure how to search for answers because it works the first time but fails on retires. I'd be very happy to be pointed to an existing thread or solution.
I'll post a paste from my dmesg below. Perhaps it has a hint? (I am sorry but I can't seem to paste with LFs). The last message shows the usb as recognized attached but nothing further as far as IDing what it is and re-creating the ttyUSBs.
Thanks for taking the time to read this plea.
Mike
[   50.582532] usb 1-1: new high-speed USB device number 2 using ehci-pci
[   50.935061] usb 1-1: New USB device found, idVendor=0403, idProduct=6011
[   50.935064] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[   50.935067] usb 1-1: Product: Quad RS232-HS
[   50.935069] usb 1-1: Manufacturer: FTDI
[   51.006339] usbcore: registered new interface driver usbserial
[   51.006347] usbcore: registered new interface driver usbserial_generic
[   51.006353] usbserial: USB Serial support registered for generic
[   51.023554] usbcore: registered new interface driver ftdi_sio
[   51.023589] usbserial: USB Serial support registered for FTDI USB Serial Device
[   51.023606] ftdi_sio 1-1:1.0: FTDI USB Serial Device converter detected
[   51.023644] usb 1-1: Detected FT4232
[   51.028247] usb 1-1: FTDI USB Serial Device converter now attached to ttyUSB0
[   51.028261] ftdi_sio 1-1:1.1: FTDI USB Serial Device converter detected
[   51.028311] usb 1-1: Detected FT4232H
[   51.032871] usb 1-1: FTDI USB Serial Device converter now attached to ttyUSB1
[   51.032889] ftdi_sio 1-1:1.2: FTDI USB Serial Device converter detected
[   51.032927] usb 1-1: Detected FT4232H
[   51.037967] usb 1-1: FTDI USB Serial Device converter now attached to ttyUSB2
[   51.037983] ftdi_sio 1-1:1.3: FTDI USB Serial Device converter detected
[   51.038019] usb 1-1: Detected FT4232H
[   51.041199] usb 1-1: FTDI USB Serial Device converter now attached to ttyUSB3
[   80.269589] usb 1-1: USB disconnect, device number 2
[   80.269806] ftdi_sio ttyUSB0: FTDI USB Serial Device converter now disconnected from ttyUSB0
[   80.269828] ftdi_sio 1-1:1.0: device disconnected
[   80.272317] ftdi_sio ttyUSB1: FTDI USB Serial Device converter now disconnected from ttyUSB1
[   80.272342] ftdi_sio 1-1:1.1: device disconnected
[   80.272659] ftdi_sio ttyUSB2: FTDI USB Serial Device converter now disconnected from ttyUSB2
[   80.272684] ftdi_sio 1-1:1.2: device disconnected
[   80.273004] ftdi_sio ttyUSB3: FTDI USB Serial Device converter now disconnected from ttyUSB3
[   80.273031] ftdi_sio 1-1:1.3: device disconnected
[   89.035073] usb 1-1: new high-speed USB device number 3 using ehci-pci
Mike
