I ran Lynis on my Ubuntu 16.04.2 LTS guest. I have been resolving issues but after much searching (including on this site) I can't seem to find a suggestion for resolving these point losses. Any pointers would be most appreciated.
Performing test ID FILE-6430 (Disable mounting of some filesystems)
Result: found module support in kernel: insmod /lib/modules/4.4.0-81-generic/kernel/fs/cramfs/cramfs.ko
Test: Checking if cramfs is active
Result: module cramfs is not loaded in the kernel
Hardening: assigned partial number of hardening points (2 of 3). Currently having 80 points (out of 87)
Result: found module support in kernel: insmod /lib/modules/4.4.0-81-generic/kernel/fs/freevxfs/freevxfs.ko
Test: Checking if freevxfs is active
Result: module freevxfs is not loaded in the kernel
Hardening: assigned partial number of hardening points (2 of 3). Currently having 82 points (out of 90)
Result: found module support in kernel: insmod /lib/modules/4.4.0-81-generic/kernel/fs/hfs/hfs.ko
Test: Checking if hfs is active
Result: module hfs is not loaded in the kernel
Hardening: assigned partial number of hardening points (2 of 3). Currently having 84 points (out of 93)
Result: found module support in kernel: insmod /lib/modules/4.4.0-81-generic/kernel/fs/hfsplus/hfsplus.ko
Test: Checking if hfsplus is active
Result: module hfsplus is not loaded in the kernel
Hardening: assigned partial number of hardening points (2 of 3). Currently having 86 points (out of 96)
Result: found module support in kernel: insmod /lib/modules/4.4.0-81-generic/kernel/fs/jffs2/jffs2.ko
Test: Checking if jffs2 is active
Result: module jffs2 is not loaded in the kernel
Hardening: assigned partial number of hardening points (2 of 3). Currently having 88 points (out of 99)
Hardening: assigned maximum number of hardening points for this item (3). Currently having 91 points (out of 102)
Result: found module support in kernel: insmod /lib/modules/4.4.0-81-generic/kernel/fs/udf/udf.ko
Test: Checking if udf is active
Result: module udf is not loaded in the kernel
Hardening: assigned partial number of hardening points (2 of 3). Currently having 93 points (out of 105)
Checking permissions of /usr/share/lynis/include/tests_storage
File permissions are OK
Pablo Bianchi
  • 17,371
MikeJRamsey56
  • 131
I found the answer. Edit file
/etc/modprobe.d/blacklist.conf
and add the following to the end
# instruct modprobe to force inactive modules to always fail loading
install cramfs /bin/false
install freevxfs /bin/false
install hfs /bin/false
install hfsplus /bin/false
install jffs2 /bin/false
install udf /bin/false
MikeJRamsey56
  • 131
