I currently have PHP 5.3 installed with Apache in 10.04 Lucid. How can I add the PHP Curl libraries? Do I need to install any other dependencies for curl?
I believe that the package php5-curl should do the trick. Use the package manager of your choice and the deps should be taken care of.
sudo apt-get install php5-curl
You will need to restart the server afterwards:
sudo service apache2 restart
Alternatively, if you are using php-fpm, you'll need to restart php5-fpm instead
sudo service php5-fpm restart
- 15,610
- 3,371
For the subversion php5.6 use the following command (tested for Ubuntu 14.04):
sudo apt-get install software-properties-common
sudo add-apt-repository ppa:ondrej/php
sudo apt-get update
sudo apt-get upgrade
sudo apt-get install php5.6
php — version
sudo apt-get install php5.6-curl
- 4,695
- 21
- 74
- 102
My conf: Ubuntu 11.10, already installed mysql,php5 and apache2, before installing php5-curl in terminal I did:
edit sources list like:
sudo -H gedit /etc/apt/sources.list
you can check your configuration in http://repogen.simplylinux.ch/
Next command:
apt-get install aptitude
Next command:
aptitude install php5-curl
You get something like this:
The following NEW packages will be installed:
php5-curl{b}
0 packages upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 27.1 kB of archives. After unpacking 127 kB will be used.
php5-curl: Depends: php5-common (= 5.3.6-13ubuntu3.1) but 5.3.6-13ubuntu3.8 is installed.
The following actions will resolve these dependencies:
Keep the following packages at their current version:
1) php5-curl [Not Installed]
Accept this solution? [Y/n/q/?] n
Your answer here is n
Next lines print out:
Downgrade the following packages:
1) libapache2-mod-php5 [5.3.6-13ubuntu3.8 (now) -> 5.3.6-13ubuntu3.1 (oneiric)]
2) php5 [5.3.6-13ubuntu3.8 (now) -> 5.3.6-13ubuntu3.1 (oneiric)]
3) php5-cli [5.3.6-13ubuntu3.8 (now) -> 5.3.6-13ubuntu3.1 (oneiric)]
4) php5-common [5.3.6-13ubuntu3.8 (now) -> 5.3.6-13ubuntu3.1 (oneiric)]
5) php5-gd [5.3.6-13ubuntu3.8 (now) -> 5.3.6-13ubuntu3.1 (oneiric)]
6) php5-mysql [5.3.6-13ubuntu3.8 (now) -> 5.3.6-13ubuntu3.1 (oneiric)]
Accept this solution? [Y/n/q/?] y
Your answer here is y.
In your browser open phpinfo(), check property:
extension_dir /usr/lib/php5/20090626+lfs
In that folder you should now have curl.so
Edit php.ini
nano /etc/php5/apache2/php.ini
find "dynamic extensions" add code below:
extension=curl.so
After that restart apache2 and check phpinfo(), curl must be enabled
- 207,228
- 71
full solution for install LAMP and cURL extension:
sudo apt-get update
sudo apt-get install libapache2-mod-php5
sudo apt-get install curl libcurl3 libcurl3-dev php5-curl
and then:
cd /etc/php5/apache2/
sudo nano php.ini
add this command: extension=curl.so
the last thing restart apache
- 173
Run following command
sudo apt-get install curl libcurl3 libcurl3-dev php5-mcrypt php5-curl
- 207,228
For php 5.6 this will do the trick:
- 133
