19
The Debian mailing list has a post relevant to some Skylake and Kaby Lake users: [WARNING] Intel Skylake/Kaby Lake processors: broken hyper-threading
Users are to run
grep name /proc/cpuinfo | sort -u
to obtain their processor details and then to check http://ark.intel.com/products/codename/37572/Skylake or http://ark.intel.com/products/codename/82879/Kaby-Lake as appropriate.
If their processor is listed, they should next run
grep -q '^flags.*[[:space:]]ht[[:space:]]' /proc/cpuinfo && \
echo "Hyper-threading is supported"
According to a follow-up post, the above command which I've struck through is not reliable and users need to run lscpu and check if
the lscpu output reports: "Thread(s) per core: 2", that means hyper-threading is enabled and supported.
If hyper-threading is supported, advice is provided for both Skylake and Kaby Lake.
I have an affected Skylake processor on 16.04 which can be fixed because
grep -E 'model|stepping' /proc/cpuinfo | sort -u
returns
model       : 78
model name  : Intel(R) Core(TM) i3-6006U CPU @ 2.00GHz
stepping    : 3
For such processors the fix suggested is to install
the non-free "intel-microcode" package with base version 3.20170511.1, and reboot the system. THIS IS THE RECOMMENDED SOLUTION FOR THESE SYSTEMS, AS IT FIXES OTHER PROCESSOR ISSUES AS WELL.
But the 16.04 repo shows me an older version:
apt policy intel-microcode
intel-microcode:
Installed: (none)
Candidate: 3.20151106.1
Version table:
3.20151106.1 500
500 http://archive.ubuntu.com/ubuntu xenial/restricted amd64 Packages
Is it possible to get the recommended version and, if it is possible, how can I do so?
Edit: I found https://launchpad.net/ubuntu/xenial/+package/intel-microcode but they all seem to be older versions.
Second edit: https://launchpad.net/ubuntu/+source/intel-microcode has the relevant update but it is for Artful Aadvark.
muru
  • 207,228
DK Bose
  • 44,553
Install the latest official package manually. i.e. for 64-bit OS:
wget http://ftp.us.debian.org/debian/pool/non-free/i/intel-microcode/intel-microcode_3.20170511.1~bpo8+1_amd64.deb
sudo dpkg -i intel-microcode_3.20170511.1~bpo8+1_amd64.deb
Reboot the machine, and you're set. ALSO, you need to install the latest BIOS update from your machine. Consult with your computer's manufacturer for the latest official BIOS update.
Cloud
  • 527
You can install the package that is for artful.
This package contains binary firmware. It is release independent.
Pilot6
  • 92,041
You can install the bios update using windows pe.
Windows setup media contains windows pe. The cmd shell can be brought up by pressing shift + f10 to access the bios executable updater.
