Well, I'm trying to open image file located in my NTFS hard drive in Ubuntu OS and I get this error
Could not load image 'image name'
Error reading from file: Permission denied
I already set the ownership of the files to -rwx-rwx-rwx using this command in terminal
chmod 777 * and also tried chmod 644 *
but still get the same error message.
Second try, I've installed Windows 7 in VMWare Player, share my folder to Windows, still no luck. I get error S-1-1-0 permission error in Windows while trying to copy/open the files.
I've using Windows 7 before, I was be able to open the files. I get the error message after I deleted my Windows 7 and installed Ubuntu as my daily driver.
I've created ext4 partition in Ubuntu and need to move all the file from NTFS drive to the new one.
These image files are so important to me, I need to at least open/read the image in Ubuntu Linux and save/copy it to the new ext4 drive.
Any help will be much appreciated. Thank you.
M Ansyori
  • 113
  • Try this Out
    install ntfs-3g by:
    sudo apt-get install ntfs-3g
  • Then run the ntfsfix command on your NTFS partition.
  • For example:
    ntfsfix /dev/sda4
  • Can refer this for futher understanding
    Problems with ntfs partitions ubuntu
