83
I am running a Odroid with Ubuntu Mate. I need to download qt and so I need to know if I should get the 32 or 64 bit version of qt.
odroid@odroid:~/software/qt5$ uname -i
armv7l
uname -i returns armv7l. Does that mean I should download the 32 or 64 bit of qt?
Lightsout
  • 1,008
  • 14
armv7l is 32 bit processor.
If you need a little bit more information regarding ARMv8, please read @Rinzwind's answer :-)
Dipesh KC
  • 1,081
32
ARMv8 is 64-bit with 32-bit compatibility. Anything lower (like ARMv7) is 32-bit.
The ARMv8 architecture introduces 64-bit support to the ARM architecture with a focus on power-efficient implementation while maintaining compatibility with existing 32-bit software. By adopting a clean approach ARMv8-A processors extend the performance range available while maintaining the low power consumption characteristics of the ARM processors that will power tomorrow's most innovative and efficient devices. ARM has 3 different product tiers supporting the ARMv8-A architecture: High Performance, High Efficiency, and Ultra-High Efficiency.
ARMv8-A introduces 64-bit architecture support to the ARM architecture and includes:
  • 64-bit general purpose registers, SP (stack pointer) and PC (program counter)
  • 64-bit data processing and extended virtual addressing
Two main execution states:
  • AArch64 - The 64-bit execution state including exception model, memory -model, programmers' model and instruction set support for that state
  • AArch32 - The 32-bit execution state including exception model, memory model, programmers' model and instruction set support for that state
redseven
  • 842
  • 14
Rinzwind
  • 309,379
