If I try to install mongo on Ubuntu 14.04 with:
sudo apt-get install -y mongodb-org
I get the error:
Reading package lists... Done
Building dependency tree
 mongodb-org : Depends: mongodb-org-shell but it is not going to be installed
               Depends: mongodb-org-server but it is not going to be installed
               Depends: mongodb-org-mongos but it is not going to be installed
               Depends: mongodb-org-tools but it is not going to be installed
This similar question recommends running apt-mark showhold to find the held packages and unhold them, but it shows nothing being held.
What's causing this error and how do I fix it?
I'm installing Mongo from Mongo's PPA. And I had previously had PPAs enabled for both the 3.0 and 3.4 versions. I removed the file /etc/apt/sources.list.d/mongodb-org-3.0.list for the 3.0 version, to avoid conflicts, but I think there still might be some lingering issues.
Cerin
  • 6,923
I had the same problem and the problem was that libcurl3 wasn't installed. this should work.
sudo apt install libcurl3
It wasn't immediately obvious, but when I went back over the docs, I realized I installed the PPA for the wrong Ubuntu version. Removing that and installing the correct one fixed the error.
Cerin
  • 6,923
