Where can I find the commands for the startup programs? The name part is easy but I have no clue about where the commands are. Browsing option does not help much. I'd like to have at start Chromium, Audio recorder, Focus Writer, SD card, Sound setting.
I am looking for the commands to enter in the command box of the Startup Applications. The question "How do I start applications automatically on login?" does not explain how to show the Main Menu.
Larry Golade
  • 1,101
  • 17
If you are looking for the links to start installed graphical programs (that you can drag to the launcher bar or copy + paste to your desktop), they are in the directory /usr/share/applications/ and end with the suffix .desktop.
Example for automounting disks with Startup Applications :
udisksctl mount --block-device /dev/disk/by-uuid/01D0EED1CBC97EE0. The hexadecimal UUID can be found with terminal command: ls -al /dev/disk/by-uuid/.
I partially found what I was looking for: for example to have Sound settings at log in, I dragged the Sound Settings icon onto the Startup Applications window. The result in the command box is: unity-control-center sound.
This does not work for the SD Card icon though.
Zanna
  • 72,312
Larry Golade
  • 1,101
  • 17
